I was using TIMER1 PPI and GPIOTE to setup a PWM signal on a GPIO line. This PWM will start and stop after 1 seconds. I used led.c to based my code. I was starting the Timer1 when the BLE_CONNECT_EVT came in but noticed that the PWM signal was locked up for about 4-5seconds before turning off. It worked fine if I trigger the PWM start on a button push, or system start-up. But if I used it at BLE_CONNECT_EVT, everything locks up. I re-tested with only using app_timers to blink and LED on the same CONNECT event, and same the thing happens. Since I use an app_timer to control both led and buzzer, the root cause may be app-timers. Has anyone encountered this?
Thanks guys
p.s. I'm not using the scheduler for any of my timers.
