BLE_ERROR_GATTS_SYS_ATTR_MISSING error upon transmission attempt in keyboard example
Been posting a few threads lately on my attempt to get the ble_app_hids_keyboard example to work on PCA10003.
I've gotten the files to compile using Eclipse on OS X. However, nothing happens when I short the button GPIO to ground. I spent some time debugging with LEDs, and have found that after a valid button press is registered, the softdevice returns BLE_ERROR_GATTS_SYS_ATTR_MISSING when the key press is actually being sent.
The source code suggests making sure to call sd_ble_gatts_sys_attr_set in the case of this error. I have found this function used only once in this project; in the device_manager_peripheral.c file. When I go to this file, the static function definitions are highlighted as syntax errors, as if this file wasn't "connected" to the rest of the project.
I kind of had to do some hacking to get this toolchain set up on eclipse...is it possible that my build is configured incorrectly somehow? I am using the source code straight from the Nordic SDK with minimal modification (just changing button/pin assignments).
Thanks again for the support!
