sad
How have you connected the LED? Did you connect the LED to GPIO P1.02 (pin # 39 on the module)? Note that the pin numbers used in the application is referring to the GPIO number (PORT_NUMBER*32 + PIN_NUMBER).
Yes it is connected to P1.02. If in SPI config I choose 34 for SCK and trasmitting i see the light
Which SDK version are you using? Have you tried both setting and clearing the GPIO? Have you tried setting the GPIO manually without the GPIO HAL functions?
NRF_P1->PIN_CNF[2] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos) |
(GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) |
(GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos) |
(GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) |
(GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos);
NRF_P1->OUTSET = (1UL << 2); // Set GPIO P1.02 high
NRF_P1->OUTCLR = (1UL << 2); // Set GPIO P1.02 lowI just tried, incl. on zero port on several pins.
Unfortunately, the result is zero. Maybe you need some PPI settings or disable standard UART or something else.
During the tests - additionally did not include anything. If you enable SPI 0 and output MOSI or SCK on the same P 1.02 - everything works, I see the signal visually (on the LED) and on the oscilloscope - the signal is clear.
I tested both codes on a nRF52840 DK. Both work as expected. Please make sure the pins are not configured for anything else when using as GPIO (SPI, etc.). Do you see any pin change on your scope?
