can I use an nRF52840 based BLE gateway? Backhaul would be either 10/100 Ethernet (via Wiznet or Microchip controller chip) or a cellular module. Is the clock speed sufficient? Is there enough RAM?
Use it for what?
Again, that depends upon your requirements!
Use the nrf52840 as a BLE gateway which means wirelessly connect BLE sensor nodes to the Ethernet (IP) either with cellular, WiFi, of wired Ethernet backhaul. I would like to connect up to 20 BLE beacon endpoint nodes.
which means
It may be what you want to do - but it isn't inherent in the words themselves.
We are not mind readers - that's why you need to explain what you're thinking of!
Should be doable.
But not a beginner's project.
Rigado uses an NXP iMX6 A7 with MTG based by module so not quite what I am looking to do.i want to use the 52840 M4 with either a cell back haul or wired 10/100 Ethernet via SPI to Ethernet controller chip such as wiznet w5500.
