NRF52 gcc set-up error
After long time again started working on nordic controller's.
Previously my pc was properly configured for NRF5x environment which includes gcc and flahser.
Recently i got nrf52832 board and i started working on..
now, I set up the path for arm-none-eabi-gcc toolchain. and export the path arm-none-eabi-gcc toolchain..
But while compiling i got following error's.
~/projects/nrf5x/sdk/nRF5_SDK_15.2.0_9412b96/examples/peripheral/blinky/pca10040/blank/armgcc
/home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: 1: /home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: ELF: not found
/home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: 2: /home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: Syntax error: "(" unexpected
Cannot find: '/home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc'.
Please set values in: "/home/stech/projects/nrf5x/sdk/nRF5_SDK_15.2.0_9412b96/components/toolchain/gcc/Makefile.posix"
according to the actual configuration of your system.
../../../../../../components/toolchain/gcc/Makefile.common:129: *** Cannot continue.  Stop.
And changed the file nRF5_SDK_15.2.0_9412b96/components/toolchain/gcc/Makefile.posix.
following is the updated file.
GNU_INSTALL_ROOT ?= /home/stech/compiler/gcc/gcc-arm-none-eabi-6-2017-q2-update/bin/
GNU_VERSION ?= 6.3.1
GNU_PREFIX ?= arm-none-eabi
I am using SDK 15.02 and i was trying the blinky from following path
  • Hi Again,
    Here are few more details,
    when i tried to check the version then also getting error.
    arm-none-eabi-gcc --version
    bash: /opt/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-gcc: cannot execute binary file: Exec format error
    i am using ubuntu 16.04 32-bit..
    here are the arm-gcc version i tried.
    gcc-arm-none-eabi-4_8-2014q3-20140805-linux.tar.bz2
    gcc-arm-none-eabi-6-2017-q2-update-linux.tar.bz2
    gcc-arm-none-eabi-7-2018-q2-update-linux.tar.bz2
    what could be the problem?
    I suspect you've downloaded the 64-bit binary of gcc.
    You can check this with the "file" program:
    file /path/to/arm-none-eabi-gcc
    Here's the output on my PC, which is a 64-bit installation:
    $ file /opt/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc
    /opt/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.24, BuildID[sha1]=285d78b4cb3e9beed1eb7191539803fc960f16f6, stripped
    the prebuild binaries were switched to 64 bit some years ago. The latest one with 32 bit linux binaries is "5-2016-q3-update"
    Håkon
  • yes, the issue was of os version. I was using 64-bit version and my os is of 32-bit.
    It is working fine now...
