NFC and LFCLK initialization
I'm experiencing a problem with the NFC.
I'm trying to make a simple read-only tag, and I've used the NFC Text Record Example to build upon. That worked without a problem.
However, when I integrated the NFC code in my project, I wasn't able to read out the tag any more, the reader said it was empty. However, I got no error code from the nfc library/code.
When I shuffled my code around, I found out that the problem has to do with the low frequency clock configuration I used:
void LFCLK_Config(void)
    ret_code_t err_code = nrf_drv_clock_init();
If I configure the LFCLK first, the program runs, but the NFC tag is empty. If i configure the NFC first, I'll get a NRF_ERROR_MODULE_ALREADY_INITIALIZED error from the nrf_drv_clock_init() call. Unfortunately, I need the LFCLK to drive my RTC.
I havn't found anything in the documentation that forbits the use of LFCLK when using NFC (using nRF52840, there shouldn't even be the timer 4 restriction).
Is there a way to solve this?
I'm using a nRF52840 and SDK version 15.
I've found the Patch for nrf_nfct_field_event_handler() function and applied it; it made no difference.
     Lasse
  • The nrf_drv_clock_init() is already run by the NFC example: fc_t2t_setup(..)-->hal_nfc_setup(..)-->nrf_drv_clock_init().
    In the LFCLK_Config() function try to run nrf_drv_clock_init_check() first, and only initialize the clock module if it is not already initialized.
    Simon
  • Hello Simon,
    I don't have to check if the clock module is initialized; when I initialize the NFC first, it always is.
    Not executing the code in LFCLK_config() doesn't do what I need:
    Skipping
    let's me use the LFCLK for my application; the NFC tag is readable, but empty.
    Also skipping
    the Tag is readable and contains the data I configured with NFC_NDEF_TEXT_RECORD_DESC_DEF, but the LFCLK isn't avaliable (more precisely: my RTC handler won't be called).
  • Hello Simon,
    Skipping
    Also skipping
