app_timer has crashed on running
My code( I add a source code lower ) has error on bold line printing NRF_ERROR_INVALID_STATE. The program uses three timers and init by "MAX_TIMERS = 6" and "OP_QUEUE_SIZE = 5".
Because of NRF_ERROR_INVALID_STATE, I create new timer before start timer(bold line!) but in that case, app_timer_create() is crashed by NRF_ERROR_NO_MEM. Before I said, the program not use timers over "MAX_TIMERS = 6". Even I increase values of "APP_TIMER_MAX_TIMERS" and "APP_TIMER_OP_QUEUE_SIZE" but same problem occurs.
I don't know that what is wrong on my code.
Thanks.
int main() {
timers_init();
ble_start();
for (;;)
        uint8_t CurFrm[MAX_BLE_DATA_LENGTH] = {0,};
        NVIC_DisableIRQ(UART0_IRQn);
        popFrmQueue(CurFrm);
        NVIC_EnableIRQ(UART0_IRQn);
        if ( CurFrm[RF_TYPE_IND] == RFTYPE_RF) {
            ble_stop();
            RF_init(addr);
            memcpy(packet,(CurFrm+1), MAX_BLE_DATA_LENGTH-1);
            RF_send();
            ble_start();
        } else if ( CurFrm[RF_TYPE_IND] == RFTYPE_BLE ) {
            if ( BLE_CONN_FLAG == true ) {
                err_code = app_timer_start(m_data_send_timer_id, DATA_SEND_INTERVAL, NULL);
            TIMEOUT_FLAG = false; // timeout flag init
            **err_code = app_timer_start(m_wait_timer_id, BLE_TX_COMPLTE_WAIT_INTERVAL, NULL);**
            while (BLE_TX_COMPLETE_FLAG != true && BLE_CONN_FLAG == true && TIMEOUT_FLAG != true) {
                err_code = sd_app_event_wait();
            err_code = app_timer_stop(m_wait_timer_id);
            simple_uart_putstring((const uint8_t *)"ble tx complete end\r\n");
            if ( BLE_TX_COMPLETE_FLAG == true ) {
                err_code = app_timer_stop(m_data_send_timer_id);
                BLE_TX_COMPLETE_FLAG = false;
return 0;
  • The only cases in which app_timer_start can return invalid state should be if the module isn't initialized or if the timer_id_t you try to start isn't actually created. I therefore suspect that the error is in your timers_init() function, either in that the APP_TIMER_INIT() is done incorrectly or that the m_wait_timer_id isn't created properly.
    Remember that you can see the source code of all the app_ modules, which makes it easier to find errors like this. The relevant checks of app_timer_start are like this:
    if (mp_nodes == NULL)
    if ((timer_id >= m_node_array_size) || (timeout_ticks < APP_TIMER_MIN_TIMEOUT_TICKS))
        return NRF_ERROR_INVALID_PARAM;
    if (mp_nodes[timer_id].state != STATE_ALLOCATED)
  • Thanks for your answer.
    I create "m_wait_timer_id" in timers_init() on starting system. So, I create the timer next above app_timer_start() (create(m_wait_timer_id)->start(m_wait_timer_id)), but the program print same error or print NRF_ERROR_NO_MEM on that app_timer_create(m_wait_timer_id). I guess this effect is that timer_id isn't freed by something causes, is it possible?
  • I'm not quite sure I understand what you mean, and to debug this properly, it would have been useful if you could upload your complete project, either here or in confidentiality in a support case.
    If creating a timer returns NO_MEM, that seems to indicate that you try to create more timers than you initialize the app_timer module with. If starting a timer returns NO_MEM, that indicates that the OP_QUEUE_SIZE is too small. However, if you do all the operations from the main loop, as your code snippet indicate, I can't quite see how this could be a problem.
  • Sorry for replying late. I don't know you comment additionally. I think notification tap doesn't alarm about comment.
    I'll send message soon.
    Always thanks Ole.
    • yjpark
