Strange value of ADC nrf51822
I'm coding a feature to measure the battery voltage via the internal VDD with an ADC.
The result I get from a 2,75 voltage source is 170.
When using the calculation ((((ADC_VALUE) * 1200 ) / 1023) * 3) my output would be 598mV.
The calculation is coming from: ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / 10BITS) * ADC_PRE_SCALING_COMPENSATION)
The ADC measures the same voltage when using 8 or 9 bit selection.
We use the nRF5 SDK 12.2.0. See below my code:
INIT:
ret_code_t ret_code;
	nrf_drv_adc_config_t adc_config = NRF_DRV_ADC_DEFAULT_CONFIG;        //Get default ADC configuration
	static nrf_drv_adc_channel_t adc_channel_config;
	adc_channel_config.config.config.resolution = NRF_ADC_CONFIG_RES_10BIT;
	adc_channel_config.config.config.input      = NRF_ADC_CONFIG_SCALING_INPUT_ONE_THIRD;
	adc_channel_config.config.config.reference  = NRF_ADC_CONFIG_REF_VBG;
	adc_channel_config.config.config.ain        = NRF_ADC_CONFIG_INPUT_DISABLED;
	ret_code = nrf_drv_adc_init(&adc_config, ADC_event_handler);              //Initialize the ADC
	APP_ERROR_CHECK(ret_code);
	nrf_drv_adc_channel_enable(&adc_channel_config);                          //Configure and enable an ADC channel
SAMPLE:
	uint32_t p_is_running = 0;
	ret_code = nrf_drv_adc_buffer_convert(adc_buffer, 6);       // Allocate buffer for ADC
	//Request the external high frequency crystal for best ADC accuracy. For lowest current consumption, don't request the crystal.
	sd_clock_hfclk_request();
	while(! p_is_running) {          //wait for the hfclk to be available
	    sd_clock_hfclk_is_running((&p_is_running));
	for (uint32_t i = 0; i < 6; i++)
	    while((NRF_ADC->BUSY & ADC_BUSY_BUSY_Msk) == ADC_BUSY_BUSY_Busy) {}   //Wait until the ADC is finished sampling
	    nrf_drv_adc_sample();        // Trigger ADC conversion
Bluetooth does not run at the moment I do a sample.
Maybe good to add, we are writing code in C++.
