Adapting BLE Eddystone Beacon Example
Good day,
I wish to adapt the Eddystone Beacon example for nRF51822 with S130 in e.g.:
..\nRF5_SDK_12.3.0\examples\ble_peripheral\ble_app_beacon\pca10028\s130\armgcc
as follows:
1)  Configure slot 1 as TLM in the application code (retain slot 0 as default URL);
2)  Disable 'connectability' in the code (as per step 1 above, this will no longer be required);
3)  Increase period between transmissions
all in order to reduce power consumption.
Please provide information as to how/where to implement the above changes.
Thank you.
Regards
Jacques
  • Hi ,
    I sincerly apologize for the very late reply. This one fell through the cracks. Are you still having issues with the Eddystone example?
    Best regards
    Bjørn
  • No problem Bjørn,
    I am using my beacons as described above, but would like to have the possibilities outlined above i.e.
    - TLM frames also able to transmit -30dBm like one can with URL frames
    - increase the interframe period to longer than 10.23 seconds
    Possibly the Eddystone specification is prescriptive in this regard, so cannot be changed?
    Thank you
    Regards
    Jacques
  • Hi Bjørn
    I assume no further update means you're unable to recreate the issue?
    I decided to try the following:
    In ..\examples\ble_peripheral\ble_app_eddystone\es_app_config.h set the value of DEFAULT_FRAME_TX_POWER to 0xEC which is -20dBm and recompile.  This seems to have caused the NRF Beacon for Eddystone Android app to show -20dBm for the TLM framem, and can be adjusted to other values.
    However this experience was short-lived, so still trying to recreate the steps to have consistent results  I am beginning to think that either the Android app has a bug, or is problematic on the 2 Android versions I am using (4.3 and latest) on 3 different phone models (Huawei phone, Huawei tablet and Moto G5).
    In the meantime please let me know how I can change es_app_config.h to only have slot 0 send out TLM frame at -20dBm (i.e. nothing in slots 1 to 4)?
    Thank you
    Jacques
    EDIT:
    Solution probably as follows: in es_app_config.h:
    - under "// Eddystone URL data" add 2 new lines:
    #define APP_ES_TLM_FRAME_TYPE ES_FRAME_TYPE_TLM
    #define DEFAULT_FRAME_TYPE APP_ES_TLM_FRAME_TYPE
    - change default power:
    #define DEFAULT_FRAME_TX_POWER 0xEC <<< or whatever power level
    I will try that tonight.
    EDIT2:
    The changes above did the trick in nRF5_SDK_15.3.0_59ac345 on my nRF52-DK, but on my nRF51422 (PCA10028) beacon the power setting stays on 0dBm (using S130 and nRF5_SDK_12.3.0)...
    EDIT3:
    I finally found nrf_ble_es.c in nRF5_SDK_12.3.0 where radio_tx_pwr is set to 0.  I changed that to DEFAULT_FRAME_TX_POWER so now my TLM beacon transmits at -20dBm on start-up.
