SPI Always consume about 1 mA on ble
Hi!!
I changed the example of SDK14.0.0's ble_app_uart and I am doing low power consumption.
I used timer interruption and now I am driving with power consumption of 1.2 ~ 1.4 mA.
But my goal is to drive the sensor at around 300 μA.
Consumed current was reduced by referring to the technology part below that reduces current consumption.
①DC-DC enabled②use of timers③turnning connection parameters④Put power_manager in for statement and enter system on mode at all times
https://devzone.nordicsemi.com/tutorials/b/hardware-and-layout/posts/nrf51-current-consumption-guide
Data is transmitted every 8 ms by SPI.
I enabled SPI on SPI when sending data and disabled SPI when I was not sending data.
static void timer_timeout_handler(void * p_context)
		static uint8_t       m_tx_buf[1];
		uint16_t length = 16;
		static uint8_t       m_rx_buf[16];
		m_tx_buf[0] = 0x00;
		if(0 == nrf_gpio_pin_read(30)){
	//	NRF_SPI1->ENABLE = 1;
	//	nrf_delay_ms(2);
		nrf_delay_us(100);
		nrf_drv_spi_transfer(&spi, m_tx_buf, 1, NULL, NULL);
		nrf_delay_us(100);
		nrf_delay_us(100);
		nrf_delay_us(100);
		nrf_drv_spi_transfer(&spi, m_tx_buf, 1, m_rx_buf, 2);
		m_rx_buf[buf_count] = *m_rx_buf;
		buf_count++;
		nrf_delay_us(100);
					if(buf_count >= 16){
						ble_nus_string_send(&m_nus, m_rx_buf, &length);
						for(int i = 0;i>buf_count;i++){
							m_rx_buf[i] = 0;
						buf_count = 0;
		nrf_delay_us(100);
		nrf_delay_us(100);
		//nrf_delay_ms(2);
		//NRF_SPI1->ENABLE = 0;
Also, I will buffer the data with SPI and send data by ble. Should UART be overcome for low power consumption?
 However, data transmission was not completed.
①Where should I fix to solve this problem?
②What else should we do to lower the average current consumption to 300 μA other than this?
If you have something to know, please let me know!!!
thank you in advanced!!!
  • Should UART be overcome for low power consumption?
    What do you mean with this?
     So does the application stop there? Does it continue? Do you receive the SPI data on the other side of the link? Do you receive parts of it?
    Can you check the return values of nrf_drv_spi_transfer()?
    err_code = nrf_drv_spi_transfer();
    This also applies when you initialize the SPI.
    The SPI shouldn't consume this amount of current.
    How do you measure the current consumption?
    Can you try to disable the SPI (not initialize it at all, and don't use it),  does the current consumption go down then? Or could it be something else drawing power? Does your application go to sleep?
    I also see that you use a lot of nrf_delay_us(). This is not really lucky when you are using the softdevice. It can cause asserts if the softdevice misses a time critical event. This could also be the cause of your "data transmission was not completed" issue.
    My main suggestion is to check the return values of the functions that return,  such as your spi functions. Also, if the application "stops working", "crashes", "freezes", or "stops advertising", please define DEBUG in your preprocessor definitions, and watch the log. It is probably an APP_ERROR_CHECK() catching an err_code != NRF_SUCCESS.
    Edvin
  • thank you for your reply!
    sorry,I wanted to ask if UART should be stopped :(
    I put a function to stop the UART before the main loop.
    Even though I do not use UART, UART was enabled.
    In that case, I was able to lower the average current consumption to about 350 μA.
    thank you for your advice!!
  • Hi!
    For low power consumption, I am considering putting it in deep sleep mode when data transmission is not done by SPI communication.
    However, the data transmission interval is as short as 8 milliseconds, during which deep sleep mode is entered. I want to wake up before sending the data and send the next data
    How long will it take to enter deep sleep mode and get up?
    Is it possible to reduce power consumption considerably by putting it in deep sleep mode?
    best regards!!!
  • Yes. It is possible to put the nRF in deep sleep to save some power. Note that this is like turning the chip off, and it will start from the top of your main() function when it wakes up. Also, to wake it up, you need an external interrupt. That is either by a pin interrupt, power on cycle, or an NFC interrupt. You can't have any timers running while in deep sleep, so you can't wake up on a timer interrupt.
    It does take some time to wake up from deep sleep, and you have to enable the peripherals, so if you are transmitting every 8ms, I don't think this would be beneficial.
    If you want to lower your current consumption, you should use the power_manage() function that is used in the ble_app_uart example to make the device go to "not deep" sleep. Then you can wait for timer timeout events.
    Edvin
    I was able to lower it to 400 μA as a result of taking the average consumed current several times using timer interrupt and power_manager (). But constantly
    However, we constantly consume about 200 μA of current. Is there any good plan as a way to lower this current consumption?
    what is the rise time from system off mode? Also, is there anything that shows the rise time from system off mode?
    best regards!!
