no EVENT_RX_SEARCH_TIMEOUT event
Hello, I have a master configured as "Bidirectional Master Channel" and a slave configured as "Bidirectional Slave Channel". Both talk to each other. When I start just the slave, I expect to receive the EVENT_RX_SEARCH_TIMEOUT after 10 seconds. But I do not receive this event. I've set the channel id to the paired master (device# 42, device type 1, transmit type 1). I don't get the event. I want to use this event to go back and set the device ID to some wildcards.
I've expicitly set the events I want to receive (sd_ant_event_filtering_set( FILTER_EVENT_RX_SEARCH_TIMEOUT | FILTER_EVENT_TX );) but this doesn't change anything. Any thoughts on what I might have missed here?
TIA Torsten
  • Use following example to get slave's timeout after 10s:
    err_code = sd_ant_channel_rx_search_timeout_set(CHANNEL_0, 2);	// 2 x 2,5 = 5s High prio search
    err_code = sd_ant_channel_low_priority_rx_search_timeout_set(CHANNEL_0, 2); // 2 x 2,5 = 5s Low prio search
    See ANT Message Protocol and Usage for defaults (Channel Search Timeout (0x44), Channel Low Priority Search Timeout (0x63)).
    If you DISABLE EVENT_RX_SEARCH_TIMEOUT through sd_ant_event_filtering_set, you'll never catch it.
  • I've missed to set application interrupt priority and to enable application interrupts. Before this, I was able to send to data and to receive data, but did not get the desired search timeout. Thanky to Petter Myhre from the Nordic support for helping me.
  • Thank you for doing the community a favor and answering your own question.
