UUID change on the fly
I have a 128bit UUID on the ad block which I need to change on the fly to another 128bit UUID.
I tried different solutions and searched for a good example, however I have not found one that would be a clear example how to do it.
I am not very proficient in C, so I have some issues with the details.
The operation should be able to be done even if a client is connected.
Some examples I tried make an error 18 if a connection is active.
Would there be a good and clear code example that will make:
1.  Stop advertising
2.  End and clear any connection if active
3.  Change 128bit UUID to another 128bit UUID in advertisement
4.  Start advertising with a new 128bit UUID
Thank you!
  • you should check ble_lbs.h
    #define LBS_UUID_SERVICE 0x1523
    #define LBS_UUID_BUTTON_CHAR 0x1524
    #define LBS_UUID_LED_CHAR 0x1525
    Thank you for the info.
    I checked through the whole project, however I do not see there any method for changing which 128bit UUID is being advertised at a time.
    The project has different services which have different UUIDs.
    I have different UUIDs too, of which only one at a time I need to advertise, and depending on state, I have to change the UUID and then advertise a different UUID.
    How to do this without resetting the device, is what I am looking for.
    Thanks!
  • I solved the problem by making the following:
    1.  Have multiple UUIDs in their own arrays.
    2.  In advertising_init, I have an IF conditional for choosing the UUID I want to use in different situations.
    3.  When I need to change the UUID, I set a variable which controls the UUID selection in advertising_init.
    4.  Then I check if a connection is active.
         If so, end the connection and wait for the event telling this has happened.
         In this event code I trigger a flag variable which makes the next step.
         If no connection is active, I do the next step directly.
    5.  Stop advertising, run advertising_init again, new UUID is selected, start advertising.
    This way the new UUID comes active almost instantly and I achieve what I was looking for.
