Reading WS2812b leftover data through I2S
Hello there,
I am currently trying to read the leftover WS2812b LED strip data which was sent using a single channel I2S. The data sent from the board (through I2S) looks like this:
with around 34 mV for high and around 2~6 mV on low. I decided not to send FFF, but 888 instead.
I am aiming to calculate the length of the LED strip. Each LED chip will read the first 24 bits of the data, cascade (discard) it, then pass it to the next one. Therefore, the strategy is to get the data after being cascaded by the last chip and calculate the length of it (which later will be divided by 24 to see how many are left).
The question is: How will I be able to read those data? I tried reading as usual (set a buffer for the i2s, start it, listen for it (delay), stop it, then check its buffer), but I got my buffer filled with all FFF instead. and a thing is that... when I tried to read anything from the pin, although I am not sending any data (the LED strip is not powered on, but connected to other's ground), there will be data, which should not happen. I assigned pin 22, 23, 24, 25 to be the i2s input pin (which will be assigned and unassigned when used or unused), and they are configured as follows:
nrf_gpio_cfg_sense_input(DIN1_PIN, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
Thank you in advance.
  • level shifter which will provide valid logic levels for the nRF
    Hmm, would you recommend one for me? I am using this one, which uses this. Will this provide valid logic levels for the nRF?
    could just use normal GPIO pins
    Hmm, are you referring to GPIOTE? Is GPIOTE interrupt fast to catch the data (as fast as i2s)?
    I have tried the example "pin_change_int", which uses GPIOTE, and here is the result:
    The yellow line is probed right to the pin which has been registered as the input to be monitored.
    The green line is probed right to the pin which has been registered as the output.
    I don't have any particular recommendations, it is up to you.
    I am not entirely sure about the questions. GPIOTE is essentially just a way to generate events on inputs or control the outputs using tasks, which is a concept used in nRF devices. Then you can hook it up to for instance a timer using PPI to measure the duration of a pulse. That could make sense in this case.
    I am not sure what I am looking at The yellow light looks like noise?
  • Okay, I stopped using COMP. As discussed above, I am confident that my Level Shifter is able to do the job: step down the data's voltage to be suitable for the nRF.
    I tried to setup a ppi with the following:
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel1, \
                                          nrf_drv_gpiote_in_event_addr_get(PIN_IN), \
    									  nrf_drv_gpiote_out_task_addr_get(PIN_OUT));
    And as a result, I got the (almost) exactly same data in the PIN_OUT as in the PIN_IN, which is as expected.
    Otherwise, this is still not done yet. nRF needs to know how many there are. Therefore, I think I should set the TEP to somewhere else. I'd like to send it to a function code. Otherwise, as Ole Morten said,
    Any task is a valid end-point for a PPI channel (not just tasks in timers and GPIOTE), but not a code function. The PPI can only be used to connect tasks and events from different peripheral blocks inside the nRF51, not co
    it seems that I can't send it to a function code. Therefore, where should I send it? Any suggestion? Timer? or..?
  • Ah right, I forgot to mention that I have made another TIMER, named "COUNTER" using this way:
    const nrf_drv_timer_t COUNTER = NRF_DRV_TIMER_INSTANCE(1);
    The argument of NRF_DRIVER_TIMER_INSTANCE is 1 because I used 0 for another timer, "MY_TIMER" (I suppose it's the right way to do it?)
    And this timer is the one I'd like to connect to the PPI as PPI's TEP.
