Reading WS2812b leftover data through I2S
Hello there,
I am currently trying to read the leftover WS2812b LED strip data which was sent using a single channel I2S. The data sent from the board (through I2S) looks like this:
with around 34 mV for high and around 2~6 mV on low. I decided not to send FFF, but 888 instead.
I am aiming to calculate the length of the LED strip. Each LED chip will read the first 24 bits of the data, cascade (discard) it, then pass it to the next one. Therefore, the strategy is to get the data after being cascaded by the last chip and calculate the length of it (which later will be divided by 24 to see how many are left).
The question is: How will I be able to read those data? I tried reading as usual (set a buffer for the i2s, start it, listen for it (delay), stop it, then check its buffer), but I got my buffer filled with all FFF instead. and a thing is that... when I tried to read anything from the pin, although I am not sending any data (the LED strip is not powered on, but connected to other's ground), there will be data, which should not happen. I assigned pin 22, 23, 24, 25 to be the i2s input pin (which will be assigned and unassigned when used or unused), and they are configured as follows:
nrf_gpio_cfg_sense_input(DIN1_PIN, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
Thank you in advance.
  • Peripheral can have event end points, which generate a pulse when there is an event. They can also have task end points, which trigger a task when they get a pulse via PPI (typically coming from an event end point). That is how you connect peripherals in nRF without using CPU and is very sensible for measuring durations of pulses (and many other tasks).
    I recommend you read up on the following:
  • Okay,
    So, I tried to assess PPI's functionality by copying the signal from the input pin to output.
    Otherwise, I figured out that there are some inaccuracy (which is crucial) created by PPI:
    I use PPI to copy the signal (purple). on the self board (dark brown), some data are not displayed well, occurs on the different board as well (red).
    Is there any way for me to increase PPI's accuracy?
    I'm using SDK v14.2. (No, I'm not mentioning about the links' SDK version, thanks for those links)
    Here's the logic analyzer file if any would like to take a deeper look (open with the Logic software by Saleae Inc.): 12 MHz, 720 M Samples [9]-2.logicdata
    (or do I need to start another thread?)
    The main point of PPI is exactly that it has very low latency and high and predictable accuracy. The 16 MHz peripheral clock is used for PPI as well, and PPI hooks up task endpoints via a single flip-flop/register, as you can see from this figure.
    No. But the problem here is not with PPI accuracy. I don't know how you have hooked things up, but I suspect that is where you will find the problem.
  • I don't know how you have hooked things up, but I suspect that is where you will find the problem.
    Here's the current setup:
    I set P0.13 as input and P0.17 (LED 1) as Output of PPI (Pink)
    and here how I initialize:
    GPIOTE:
    static void gpio_init(void)
    	ret_code_t err_code;
    	nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    	err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
    	nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    	//nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    	in_config.pull = NRF_GPIO_PIN_PULLUP;
    	err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    	//err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, null_handler);
        nrf_drv_gpiote_in_event_enable(PIN_IN, true);
    	nrf_drv_gpiote_out_task_enable(PIN_OUT);
    PPI:
    static nrf_ppi_channel_t m_ppi_channel1;
    static void ppi_init(void)
        uint32_t err_code = NRF_SUCCESS;
        // Configure 1st available PPI channel to stop TIMER0 counter on TIMER1 COMPARE[0] match,
        // which is every even number of seconds.
        err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel1);
    	//ppi_enable_channel(FC_PPI_CH, &NRF_GPIOTE->EVENTS_IN[FC_GPIOTE_CH], &FC_TIMER->TASKS_COUNT);
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel1, \
    										  nrf_drv_gpiote_in_event_addr_get(PIN_IN), \
    										  nrf_drv_gpiote_out_task_addr_get(PIN_OUT));
    	//err_code = nrf_drv_ppi_channel_assign(m_ppi_channel1, \
    										  (uint32_t)&(NRF_TIMER1->TASKS_COUNT));
        // Enable both configured PPI channels
        err_code = nrf_drv_ppi_channel_enable(m_ppi_channel1);
  • Why is what you get in the trace not expected with this code? What did you expect (and why/how)?
