I'm trying to play voice using PWM in nRF51822.
I've already experienced this using other MCU before.
So. I'm trying.
Voice source data is 8bit / 8K / mono PCM sampling data.
I call below code according to 8KHz frequency.
I write the above PCM sampling data value to below level register.
The val register value is a fixed value of 50.
At the test level, I don't execute any other code, but only this code.
And the below code is used for buzzer playback now.
I don't know what's wrong.
Could anybody let me know what's wrong or some tip?
Thanks and happy new year.
// for sound level
err_code = app_pwm_uninit(&PWM_BUZZER);
// NRF_LOG_RAW_INFO("pwm-buzzer uninit error : %d\r\n", err_code);
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(level, BUZZER_PIN);
pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
err_code = app_pwm_init(&PWM_BUZZER, &pwm1_cfg, NULL); // callback_pwmBuz);
// NRF_LOG_RAW_INFO("pwm-buzzer init error : %d\r\n", err_code);
app_pwm_enable(&PWM_BUZZER);
// NRF_LOG_RAW_INFO("pwm-buzzer enable\r\n");
// for sound strength
while(app_pwm_channel_duty_set(&PWM_BUZZER, 0, val) == NRF_ERROR_BUSY);
