NRF24L01+: what is min. delay between packets from two Tx to one Rx?
The documentation states, “Only one data pipe can receive a packet at a time”
So what is the minimum acceptable delay between the receipt of two packets to two different data pipes?
I have one receiver (PRx) and 2 transmitters (PTx1 and PTx2). I am finding that when PTx1 sends a data packet, PTx2 must wait 2ms before it can send a packet otherwise PRx may miss it. I am surprised that the delay must be this high.
I am transmitting at 250kbps and not using ACK or any re-transmits. My payload size is 9 bytes with 16-bit CRC.
    It is only possible to receive one packet at a time, even when having several pipes enabled. In your case you are using 250kbps, which means that single byte is about 32us long. If you have ack enabled, then a single tx with ack will take about: 130us + (8+9) * 32us + 130us + 8 *32us = 1.060ms. If there is interference or collision then the retransmit delay will add to this time. To ensure you are not using ack you can use the  W_TX_PAYLOAD_NOACK command and/or measure on the VDD_PA pin on the receiver, the VDD_PA pin should not toggle to 1.7V at any time, since that will indicate it is transmitting an ack.
    Kenneth
