clock_lf_cfg configuration in SDK15
Hi!
I have strange behavior.
nRF52, SD132 6.0, SDK15
I use RC clock src.
nrf_clock_lf_cfg_t const clock_lf_cfg =
.source = NRF_SDH_CLOCK_LF_SRC,
.rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV,
.rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV,
.accuracy = NRF_SDH_CLOCK_LF_ACCURACY
When NRF_SDH_CLOCK_LF_RC_CTIV = 16 and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV = 2
project under debug doesn't start first time after start. After call
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
function, there is no any answear. If project in a Keil restart, project starts normal. Also if just supply power, project always starts normal many times. But under Keil, first start always fail.
But if change to
NRF_SDH_CLOCK_LF_RC_CTIV = 0 and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV = 0
project always starts normal.
why?
  • Hi Mikhail,
     can you post the section of sdk_config.h that sets the NRF_SDH_CLOCK_XXX definitions?  The CTIV and TEMP_CTIV values are correct as far as I can tell. Are you saying that the nRF52 runs the code correctly when you're not debugging, but hangs when you run it in a debug session?
    Is this a NRF52 DK or a custom board?
    Best regards
    Bjørn
  • Thanks for answer. Sorry for long delay.
    This behavior on a custom board.
    Now I use:
    // </h>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    // </h>
    And seems it works. But it worked since I added back some queue file in the project.
    Very strange.
  • Ok, so you're now able to run the code in a debug session without the code halting?
  • Hi Mikhail,
    I got the same problem.
    I also setted to RC,16,2,500 PPM And it works OK regularly but halts in debug mode
    What do you meen by "queue file" ?!
    B,r
    Yuval
