Device get stuck when trying to read MAC address via SWD
I am using the command line tool nrfjprog to read the device MAC address using the following command:
nrfjprog --memrd 0x100000A4 --w 8 --n 6
I am connected using Segger J-link base.
My problem is that after running this command the device get stuck and i have to reset it to make it work again.
Please let me know if i should do anything different as i need to be able to read the MAC address and continue working properly.
Thank you,
Ibrahim Anabosi
    This is the expected behavior.
    nrfjprog will halt the CPU when reading the flash. If your application uses the SoftDevice, you will assert if you call "nrfjprog --run" afterwards, as the CPU is only halted, not the peripherals, which will cause a timing assertion in the softdevice. Due to this, calling nrfjprog --reset makes sense after reading out the flash.
    If you are interested in seeing the sequence nrfjprog uses, add "--log" and then have a look at the generated log.log file.
    Håkon
