What should I do in NRF 52832 to enable RS485 communication?
Hi.
I have a problem with using RS485 (ISO-3082DWR) from NRF-52832.
The SDK version uses 15.02.
Here's the code I've run.
    nrfx_uart_config_t uart_config =
        .pseltxd = 30,
        .pselrxd = 31,
        .pselcts = 19,
        .pselrts = 18,
        .p_context = NULL,
        .hwfc = NRF_UART_HWFC_DISABLED, // Flow Control - Not Use
        .parity = NRF_UART_PARITY_EXCLUDED, // Parity - Not Included
        .baudrate = UARTE_BAUDRATE_BAUDRATE_Baud19200,
        .interrupt_priority = NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY
    // TWI_INSTACE_ID Already defined 0
    nrfx_uart_t uart = NRFX_UART_INSTANCE (TWI_INSTANCE_ID);
     nrfx_err_t err;
     err = nrfx_uart_init (& uart, & uart_config, nrfx_uart_event_handler);
    // flow control - write
    nrf_gpio_cfg_output (18);
    nrf_gpio_cfg_output (19);
    nrf_gpio_pin_write (18, 1);
    nrf_gpio_pin_write (19, 1);
    while (true)
        int8_t ch = 'b';
        err = nrfx_uart_tx (& uart, & ch, 1);
        nrfx_uart_tx_abort (& uart);
        nrf_delay_ms (100);
I have processed the following code, but I do not get any signals. Is there a problem with the code?
Or do I have to look through another example?
