Nordic nRF5 SDK 15.2.0 Example Include Files in Eclipse
Is there any easier way when using Eclipse IDE with GCC for nRF5 SDK 15.2 development to get the Include files in the examples to be recognized easier than tediously defining each path? Is there modification that needs to be done to the makefile.common or any other files/settings for this to work properly? I tried an example nRF5 project in eclipse and got most of it to work fine, with the exception of the #include files not being found.
Thanks!
  • Is there any easier way when using Eclipse IDE with GCC for nRF5 SDK 15.2 development to get the Include files in the examples to be recognized easier than tediously defining each path?
    No - I have never found any way to add  multiple include paths together to an Eclipse Project.
    Disappointed
    This is a limitation of Eclipse - nothing specifically to do with Nordic.
    (I'm not sure that you can do it in Keil or SES, either)
    Note that the Eclipse Project file is just an XML file - so you could edit the file manually ...
    (many editors have syntax-highlighting support for XML; eg, Notepad++)
    Again, it's not a Nordic thing;  so you could try the Eclipse forums - it must be a common annoyance, so there may be people who have found a solution...
  • You need to add the include paths into the project settings.  The way the SDK folders are setup, there are tons of paths to set.  And yes, it is an SDK issue as well for bad layout and programming practices.
  • It's an annoyance that has been around for a long time, not having a simple recursive include in SES and Eclipse; typically users edit a text file generated by a command like this (for each tree of includes):
    cd C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble
    dir /s *.h > includes.txt
    The edited file then can be pasted into the xml project file; it's a pain.
  • you'd need to do a bit more manual editing than just pasting that file straight into the XML - but that's the basic idea...
  • Yes, agreed. I use Brief or Codewright or Notepad++ for the excellent column editing; pity none of the IDEs seem to have that feature. To expand on the command line here's an example:
    C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble>dir *.h /S | find "Directory" > includes.txt
    C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble>type includes.txt
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_advertising
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_db_discovery
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_dtm
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_lesc
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_link_ctx_manager
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_racp
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_radio_notification
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_ancs_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_ans_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_bas
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_bas_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_bps
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_cscs
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_cts_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dis
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dis_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_escs
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_gls
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_hids
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_hrs
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_hrs_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_hts
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_ias
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_ias_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_ipsp
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_lbs
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_lbs_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_lls
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_nus
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_nus_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_rscs
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_rscs_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_tps
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\eddystone
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\experimental_ble_lns
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\experimental_ble_ots
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\experimental_gatts_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\experimental_nrf_ble_cgms
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\experimental_nrf_ble_ots_c
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\nrf_ble_bms
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\common
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\nrf_ble_gatt
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\nrf_ble_qwr
     Directory of C:\Projects\Nordic\nRF5_SDK_15.0.0_a53641a\components\ble\peer_manager
    After editing, eg for SES:
    c_user_include_directories="../../../config;../../../../../../components;../../../../../../components;../../../../../../components/ble/ble_advertising;blah-blah
    Of course, copying the includes for an SES or Eclipse existing project is usually less effort ..
