Update firmware from external flash
I have a custom board with nRF52832 and I'm using SDK 13.1 and softdevice s132 4.0.5. I have a GPRS module that I will use to receive the new firmware image and I will save it on a external flash. Once whole firmware image is downloaded and verified, I want to execute the bootloader and update the firmware. As I know, the steps to do this are:
* Download image to external flash and verify it
* Save image settings like CRC, length, etc. to external flash
* Copy the image and settings to the internal flash of nRF52
* Enter to bootloader and load the image saved in bank1 of internal flash.
When I do the update via DFU, I generate a zip packet that contains a *.bin (encrypted image) and a *.dat (is this the init packet?), are these the files that I have to send to the GPRS module? or have I to send the hex application file and image settings in clear?
When the update is via DFU, the new image is saved in Bank1, how I will know this address? Is this address accessible from the application to copy the image from the external to internal flash?
Which are the main functions I have to check in bootloader to copy de firmware of bank1 to bank0? Do you have any example code of it? The bootloader code is a little bit tricky, so any help will be appreciated.
Thanks in advance.
