Stack - nRF52 DK, SDK 15.0.0, Segger Embedded Studio, Windows. Using code examples described below.
So my high level goal is to read data from registers in an I2C sensor and send these values via Bluetooth. I'm reading I2C data using "nrf_drv_twi" rx and tx, which stores the read sensor data in variables of type uint8_t. To send data via bluetooth, I'm working out of this tutorial (https://devzone.nordicsemi.com/tutorials/b/bluetooth-low-energy/posts/ble-characteristics-a-beginners-tutorial), which in step "Step 3.F, Update the characteristic with temperature data", passes data as int32_t type variables. I'm having a lot of problems converting the uint8_t variables into any variables that aren't uint8_t (e.g. program behaves unexpectedly when storing values in uint16_t, int8_t, int32_t, etc).
So for example, I created a standalone project in Eclipse to check my sanity, just debugged locally with no build target:
#include <stdio.h> #include <stdlib.h> #include <stdint.h> int main(void) { uint8_t a = 0x12; uint8_t b = 0x34; int16_t c = 0; c = a; c = c<<8; c = c + b; return EXIT_SUCCESS; }
When debugging, variables expect exactly as I expect. After all the code is run, the debug console shows:
this is my desired output. essentially, I want to "concatenate" all the values together and parse after sending to an iOS app.
However, running the same code snippet contained in main() within a project built for the nRF52DK gives bizarre results:
I'm now noticing other weird behavior. When I first start debugging, a/b/c all have these values to start. when I change a/b to other values, e.g. 0x56 / 0x78, the debug values in the watch list remain unchanged even after those lines of code have been run. I tried setting breakpoints on each of the lines where they're running, but SES won't stop on those breakpoints and catches on one a couple lines down...
What can I do to get this code to behave as it does when building in Eclipse without a target?
Or maybe I can circumvent this problem entirely. Is there an easier way to send TWI sensor data via BLE?
