GPIO setup for CUSTOM board FANSTEL remap of leds
I have created a custom board in the boards.h file.
I then created the fanstel header file and copied the PCA10056 information accross.  Everything is working as it should except im having trouble with P1.00. I looked at this post https://devzone.nordicsemi.com/f/nordic-q-a/38788/how-to-change-tx_pin_number-to-p1-00-on-the-nrf52840, but are not getting the results.
If I hardcode the following  "nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(1, 0));" the LED turns on but I  would like to use the existing drivers and just reconfigure the GPIO map.
my fanstel.h is below but only the led on P0.11 is functioning.
#include "nrf_gpio.h"
// LEDs definitions for FANSTEL
#define LEDS_NUMBER    2
#define LED_1          NRF_GPIO_PIN_MAP(0,11)// fanstel blue
#define LED_2          NRF_GPIO_PIN_MAP(1,00)// fanstel red
#define LED_START      LED_1
#define LED_STOP       LED_2
#define LEDS_ACTIVE_STATE 0
#define LEDS_LIST { LED_1, LED_2 }
#define LEDS_INV_MASK  LEDS_MASK
#define BSP_LED_0     11//P0.11//  blue
#define BSP_LED_1     00//P1.00//  red
I dont see P1.00 used anywhere else but yet it is not  turning on with the P0.11 led when initialized.
Im using the Mesh3 timer_light example and this function to test the leds from simple_hal.c file
void hal_leds_init(void)
    for (uint32_t i = LED_START; i <= LED_STOP; ++i)
        NRF_GPIO->PIN_CNF[i] = LED_PIN_CONFIG;
        NRF_GPIO->OUTSET = 1UL << i;
Is there anything else I should add somewhere?
thanks in advance
