Low power BLE Stack
HI,
I am using NRF52832,SDK15.2
I need to work on ultra low power consumption because My project related to Health care, Fitness tracker and HOME IOT mesh network.
for that i need to work on the application, read the sensor data, broadcast the respective data to mobile or other ble device.
My expectation is to control the CPU power upto 0.6mA. Is it possible with current BLE_STACK?
or we need to modify in ble stack to achieve this perfect battery life..
for example RUUVI board provides 3.3V 1000mAh battery gives two year battery life.
they are reading the data from two different sensor and broadcast the data to their app
  • To even being to answer this question a person would need to know the connection interval, what sensors are enabled and when, what the advertising rate would be, what advertising duty cycle is required, etc.
    As we used to say back when I was in school: "You're going to have to do you own homework".
    A good place to start is the nrf52 Product Specification in their docs lib https://www.nordicsemi.com/DocLib
    Chapter 19 is the Electrical Specification.
    Literally Everything you need to know is right there.
    Thank you.,
    bu seen online power profiling..
    https://devzone.nordicsemi.com/power/
    which one i need to consider Green mark or Red mark ..
    How to cut down it into less than 1mA
    Is there any document or video tutorial related to power profiling.
    why i try to do is the following code continuously read the sensor data for every one second and broadcast to mobile phone .
    if it work in LDO power rate is 8.30mA
    and if it in DCDC power rate is 5.02mA
    but i need it to be in 0.8mA to 1mA for battery life extension . what i want to do
    how to access Tx power RX power control, CPU CACHE, every thing
    can you guide me
    #include <stdio.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "app_button.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "bmi160.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    #define G_TO_LSB (16384.0f)
    #define PI (3.14159)
    #define DPS_TO_LSB (131.072f)
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "L-SPoT_fw_v1.1"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    //#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    /* BMI_160. */
    struct bmi160_dev sensor;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    APP_TIMER_DEF(sensor_handle); // timer a
    int8_t rslt = BMI160_OK;
    int8_t rsltr = BMI160_OK;
    int8_t rsltw = BMI160_OK;
    int8_t rsltb = BMI160_OK;
    bool ble_flag = false;
    bool cali_flag = false;
    float valx, valy, valz;
    int accx, accy, accz, calib;
    char str[80];
    uint16_t length1;
    ret_code_t rssi;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
               // bsp_board_led_on(CONNECTED_LED);
                err_code = app_button_enable();
                err_code = sd_ble_gap_rssi_start(m_conn_handle, 1, 1);
                ble_flag = true;
             case BLE_GAP_EVT_RSSI_CHANGED:
               // NRF_LOG_INFO("RSSI: %d dBm", p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
               // printf("RSSI: %d dBm\r\n", p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
                rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
                NRF_LOG_INFO("Disconnected");
               // bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                ble_flag = false;
                //advertising_start();
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    //  init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    /*TWI initialization*/
    void twi_init (void)
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        if (NRF_SUCCESS == err_code)
    		nrf_drv_twi_enable(&m_twi);
    		NRF_LOG_INFO("TWI init success...");
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
        //  NRF_LOG_INFO("WRITE: dev_id: %x reg_addr: %x reg_data: %x len: %i\n", dev_id, reg_addr, *reg_data, len);
    	//int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rsltw = nrf_drv_twi_tx(&m_twi, dev_id, data, len + 1, false);
    	//APP_ERROR_CHECK(rsltw);
            return rsltw;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	//int8_t rslt = 0;
       //     NRF_LOG_INFO("READ: dev_id: %x reg_addr: %x len: %i\n", dev_id, reg_addr, len);
    	rsltr = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, true);
           // APP_ERROR_CHECK(rsltr);
    	if (rsltr == 0)
    		rsltr = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
        //    NRF_LOG_INFO("READ: %x",*reg_data);
    	return rsltr;
    void Acc_delay_ms(uint32_t period)
    /*if (period==NULL){
    period = 1;
    }// delay time*/
      nrf_delay_ms( period ) ;
    void BMI160_init (void)
        sensor.id = BMI160_I2C_ADDR;         //0x69
        sensor.interface = BMI160_I2C_INTF;  //0x00
        sensor.read = &Acc_i2c_Read;
        sensor.write = &Acc_i2c_Write;
        sensor.delay_ms = &Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        APP_ERROR_CHECK(rslt);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("BMI160 Initialized...");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized...");
        }//NRF_LOG_FLUSH();
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_12_5HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        sensor.accel_cfg.power = BMI160_ACCEL_LOWPOWER_MODE;
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_25HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        rslt = bmi160_set_sens_conf(&sensor);
        NRF_LOG_INFO("sensor Configured...");
        } else {
        NRF_LOG_INFO("sensor not Configured...");
        }//NRF_LOG_FLUSH();
     void vib()
        nrf_gpio_pin_write(17,1);
        nrf_delay_ms(80);
        nrf_gpio_pin_write(17,0);
        nrf_delay_ms(20);
    static void read_sensor_data()
          int8_t note = 0;
          bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &sensor);
        /*  NRF_LOG_INFO("DataX:%d", accel.x);
          NRF_LOG_INFO("DataY:%d", accel.y);
          NRF_LOG_INFO("DataZ:%d", accel.z);
          NRF_LOG_INFO("GyroX:%d", gyro.x);
          NRF_LOG_INFO("GyroY:%d", gyro.y);
          NRF_LOG_INFO("GyroZ:%d", gyro.z);
           NRF_LOG_FLUSH();*/
         // float accelX = ((((float)accel.x) / G_TO_LSB) * 9.80655); // in m/s^2
           valx = ( (float)(accel.x - 265)*(1.31387)+(-270));
           valy = ( (float)(accel.y- 265)*(1.31387)+(-90));
           valz = ( (float)(accel.z - 265)*(1.31387)+(-90));
        // accelX = (atan2(accel.y,accel.z)*57.3);
        //  printf("\r\n m/s^2  : %.2f \r\n",accelX);
         // accelX = (atan2((-accel.x),sqrt((accel.y*accel.y)+(accel.z*accel.z)))*57.3);
           accx= (int)(atan2(-valy, -valz)*(180/PI));//angle of forward backward
           accy= (int)(atan2(-valx, -valz)*(180/PI));
           accz= (int)(atan2(-valy, -valx)*(180/PI));// angle of right left
           accx = abs(accx);
           if(cali_flag == true)
              if (((calib - accx) >= 20) || ((accx - calib) >=30))
                      note = 1;
                      vib();
                    note = 0;
           if ((ble_flag == true)&&(cali_flag == true))
                  length1 = sprintf(str, "*%d,%d,%d#\n", accx, note, rssi);
                  rsltb = ble_nus_data_send(&m_nus, str, &length1, m_conn_handle);
         NRF_LOG_INFO("angle_X:%d", accx);
         NRF_LOG_INFO("angle_Y:%d", accy);
         NRF_LOG_INFO("angle_Z:%d", accz);
          NRF_LOG_FLUSH();
     void calib_vib()
        nrf_delay_ms(200);
        nrf_delay_ms(100);
     void calibrate_init()
        nrf_delay_ms(250);
        nrf_delay_ms(150);
        nrf_delay_ms(250);
        nrf_delay_ms(50);
    void calibration()
        int x = 1;
        for(x;x<=10;x++)
            read_sensor_data();
            calib = calib + accx;
            calib_vib();
            NRF_LOG_INFO("count : %d ", x);
            NRF_LOG_FLUSH();
            nrf_delay_ms(1000);
        calib = calib/10;
        NRF_LOG_INFO("calib : %d ", calib);
        cali_flag =  true;
        NRF_LOG_FLUSH();
    /**@brief Application main function.
        bool erase_bonds;
        uint8_t sample_data[10];
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        nrf_gpio_pin_dir_set(17, NRF_GPIO_PIN_DIR_OUTPUT);
        power_management_init();
        ble_stack_init();
        //uint32_t err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
       // APP_ERROR_CHECK(err_code);
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("BMI160 get started...");
        Acc_delay_ms(100);
        twi_init();
        Acc_delay_ms(50);
        BMI160_init();
         NRF_LOG_FLUSH();
        Acc_delay_ms(100);
        calibrate_init();
        calibration();
        // Enter main loop.
        for (;;)
            //idle_state_handle();
            nrf_delay_ms( 1000 ) ;
            read_sensor_data();
    Thanks.,
