Timer Issue
I am using "ble_app_uart" code and added battery service to it as custom changes.
I want to update battery level at every 3 seconds.
Code is working fine and starts broadcast & advertise and service information but when I call/enable timer_init() and timers_start() function on main loop it's stop broadcasting.
Can you tell me whats wrong in my code?
Here I have attached my main.c file for your reference
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "app_button.h"
#include "nrf_adc.h"
#include "ble_nus.h"
#include "ble_bas.h"
#include "app_uart.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
//#define BTN_PRESSED 1
//#define Start_pin 20
//#define End_pin	20
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define BATT_INTV_MS 										3000
// for batt services
//#define BATTERY_LEVEL_MEAS_INTERVAL          APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                    81                                         /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                    100                                        /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT              1                                          /**< Increment between each simulated battery level measuremen */
#define ADVDATA_UPDATE_INTERVAL         APP_TIMER_TICKS(BATT_INTV_MS, APP_TIMER_PRESCALER)
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define START_STRING                    "Start...\n"                                /**< The string that will be sent over the UART when the application starts. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
volatile int32_t adc_sample = 51;       																	// adc sampling variables
static ble_bas_t                        m_bas;			                                     			/**< Structure used to identify the battery service. */
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
static app_timer_id_t                   m_battery_timer_id;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 * @brief ADC interrupt handler.
void ADC_IRQHandler(void)
    nrf_adc_conversion_event_clean();
    adc_sample = nrf_adc_result_get();
 * @brief ADC initialization.
void adc_config(void)
    const nrf_adc_config_t nrf_adc_config = NRF_ADC_CONFIG_DEFAULT;
    // Initialize and configure ADC
    nrf_adc_configure( (nrf_adc_config_t *)&nrf_adc_config);
    nrf_adc_input_select(NRF_ADC_CONFIG_INPUT_2);
    nrf_adc_int_enable(ADC_INTENSET_END_Enabled << ADC_INTENSET_END_Pos);
    NVIC_SetPriority(ADC_IRQn, NRF_APP_PRIORITY_HIGH);
    NVIC_EnableIRQ(ADC_IRQn);
/**@brief Perform battery measurement, and update Battery Level characteristic in Battery Service.
static void battery_level_update(void)
    uint32_t err_code;
    uint16_t  battery_level;
    battery_level = adc_sample++;
    err_code = ble_bas_battery_level_update(&m_bas, battery_level);
    if (
        (err_code != NRF_SUCCESS)
        (err_code != NRF_ERROR_INVALID_STATE)
        (err_code != BLE_ERROR_NO_TX_BUFFERS)
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Battery measurement timer timeout handler.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Start application timers.
static void timers_start(void)
    uint32_t err_code;
    // Start application timers
    err_code = app_timer_start(m_battery_timer_id, ADVDATA_UPDATE_INTERVAL, NULL);
/**@brief Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    uint32_t err_code;
    // Initialize timer module
    APP_TIMER_INIT(APP_TIMER_PRESCALER,APP_TIMER_OP_QUEUE_SIZE, false);
    // Create timers
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
    ble_bas_init_t bas_init;
	  // Initialize Battery Service
    memset(&bas_init, 0, sizeof(bas_init));
																																										// below code is for batt services
    // Here the sec level for the Battery Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for the Application's S110 SoftDevice event handler.
 * @param[in] p_ble_evt S110 SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
            // Pairing not supported
            // No implementation needed.
/**@brief Function for dispatching a S110 SoftDevice event to all modules with a S110 SoftDevice
 *        event handler.
 * @details This function is called from the S110 SoftDevice event interrupt handler after a S110
 *          SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
	  ble_bas_on_ble_evt(&m_bas, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the S110 SoftDevice initialization.
 * @details This function initializes the S110 SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
    // Enable BLE stack.
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#if (defined(S130) || defined(S132))
    ble_enable_params.gatts_enable_params.attr_tab_size   = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_ENABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud38400
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
    uint32_t err_code;
    bool erase_bonds;
    uint8_t  start_string[] = START_STRING;
		//nrf_gpio_cfg_input(usb_sense, NRF_GPIO_PIN_NOPULL);          // to configure the buttons
		// Configure BUTTON 2 with SENSE enabled so that CPU is enabled (exit System-On low power mode) when pressing Button 2
    //nrf_gpio_cfg_sense_input(usb_sense, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_HIGH);
		//nrf_gpio_range_cfg_output(Start_pin, End_pin);
	  // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
    gap_params_init();
		//timers_init();
    services_init();
    advertising_init();
    conn_params_init();
		printf("%s",start_string);
		//timers_start();
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    //if(nrf_gpio_pin_read(usb_sense) == BTN_PRESSED)
		//			nrf_gpio_pin_set(Start_pin);
    // Enter main loop.
    for (;;)
				power_manage();
Thanks
