Using MDBT42Q and BLE
Hello:
I'm relatively new and have been using 52832 DK for several months without any problems.  It is a great product.  As I gained experience, I've tried programming other boards (GT52832_A01) using a mini J-Link that I bought from Adafruit - again without problems. All of the example programs load and run on both DK and GT boards as expected.
I recently bought a few MDBT42Q modules from Mouser (they are made by Seeed Studios).  I believe this is the same module used by Adafruit on their Featherboard 52832, so I thought this would be a good product to expand my experience.  I was able to program the MDBT42Q boards using the J-Link, however, when I try to use anything with BLE the program loads but I'm not able to connect to the board via BLE.  I load the soft device loads and then the program the same way as with the DK and GT boards, except I'm not able to connect to the MDBT42Q board.  It is as if the board isn't advertising.
I did a search in the DevZone and found one post by Sudarshan J 10 months ago that looked similar to my problem but I'm not sure how to proceed and hope you might suggest some things to try.
The datasheet for the MDBT42Q basically says that you don't need any external circuitry to make the module work, so it may not be a clock problem - but I'm not sure.  Since the module works fine (I can load simple blinky programs and program gpio, etc), I think I'm missing something simple.
Any suggestions?
A related question - I tried to use debug to set breakpoints before and after the advertising function to try to see what was happening.  I tried to go stepwise through the program but execution just stops - so I must be missing something there as well.  There is a warning that there is a 32Kb limit on evaluation in debug - is that the problem?  Any suggestions?
Thank you for your help.
  • Thanks for posting, glad you got it going!
    I'll double check my connections but the NRF52-DK seems to be flashing the MDBT42Q with the application and SD without any errors. I'm not connecting the reset pin, is that required?
    You much be using an older SDK, I don't see that macro (SOFTDEVICE_HANDLER_INIT) in version 15 of the SDK which is what I'm using. But I have tried setting the equivalent defines in the sdk_config.h so it should equate to the same settings for the clock. Still no love... I'll keep trying.
    I should add, like you the examples that don't use the SD work fine. Blinky for example runs fine as I made a board file for the MDBT42Q with proper pin configurations.
  • EXT:
    I had the exact same experience.
    I'm using version 15 of SDK also.  I've noticed a few differences in the code depending on the example  you start with and where you get the example code.  Some code has SOFT_DEVICE_HANDLER but not all.
    I'm planning to test a few variations later today and will post exactly the version I start with, changes I make, and results.
  • Please keep a civil tone. 's questions and suggestions make full sense.
    And to sum up: The only relevant difference between the 52832 DK and the MDBT42Q module is that the DK has a 32 kHz crystal and the module does not. So as long as you remember to configure the SoftDevice to use the internal 32 kHz RC instead of the non-existing 32 kHz crystal oscillator everything should work as on the DK.
  • here is what I've learned.
    From the pack installer load the "experimental_ble_app_blinky_s132_pca10040" example.
    connect the MDBT42Q and erase the chip with nRFgo Studio.
    Load the Softdevice.
    In the program comment out //SOFTDEVICE_HANDLER(NRF_CLOCK_LFCLKSCR_XTAL_20_PPM, false);
    replace with :
    SOFTDEVICE_HANDLER(NRF_CLOCK_LFCLKSCR_RC_250_PPM_250MS_CALIBRATION, false);
    load the program.  You should be able to connect by running the nRF Blinky app on your phone.  The LED on/of will toggle pin 17 and if you ground pin 13 you should see the button pressed/released toggle on the phone.
    There is still a problem with UART programs - they don't use SOFTDEVICE_HANDLER.  What is the difference between using SOFTDEVICE_HANDLER and the way connection is managed with UART program?
  • He is rude and looking at his post history he has that tone with everyone. I'll just switch to another platform if that is how this community is run.
