Ble Data Transfer Integrity
I am trying to send data from a phone to the NRF51822. The data is being sent from the phone in 20 byte chunks to a write characteristic. When the event handler for receiving data is called, I use sd_ble_gatts_value_get() to get the data and copy it to a buffer. The problem I see is that part of the previous packet is returned instead of the current one, but it does have the right length. For example, if I sent 5 20-byte packets numbered 0 - 99, the first 60 would have the right number, but byte 61 might have the number 56 instead of 60. Are there any methods to improve data integrity over BLE?
Thanks!
  • All data transferred over BLE is reliable, so I suspect you have some issues other place, for instance in the application handling in the central or peripheral. To check where the problem may be you might need to create a sniffer log and send to me when the problem occurs.
    https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRF-Sniffer
  • I have run the sniffer with my application, and I can tell that the correct data is being sent to the NRF51822. Here is the sniffer output if you are curious. The following code is called when BLE_GATTS_EVT_WRITE event occurs.
    #define MAX_PACKET_SIZE 20
    static uint8_t data_buffer[MAX_PACKET_SIZE];
    void onCharWrite(ble_evt_t * p_ble_evt)
        // Populate ble_gatts_value_t structure to hold received data and metadata.
        ble_gatts_value_t rx_data;
        rx_data.len = MAX_PACKET_SIZE;
        rx_data.offset = 0;
        rx_data.p_value = data_buffer;
        ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        uint32_t error = NRF_SUCCESS;
        const uint16_t WriteHandle = p_evt_write->handle;
        if (WriteHandle == CharWriteHandles.value_handle)
            // Get data
            memset(data_buffer, 0, MAX_PACKET_SIZE);
            error = sd_ble_gatts_value_get(zwConnection, CharWriteHandles.value_handle, &rx_data);
            APP_ERROR_CHECK(error);
            print_hex_buffer(&data_buffer[rx_data.offset], rx_data.len);
            //Copying to buffers and other processing
    Is there something wrong with the way this is being handled?
  • It may be that rx_data is only valid in the onCharWrite() context, so I assume then that print_hex_buffer() is blocking here to make sure the entire buffer is output before you return from onCharWrite()?
    Also, I believe you don't need to use sd_ble_gatts_value_get(), I assume you are in the BLE event you should be able to use:
    p_ble_evt->evt.gatts_evt.params.write.len;
    p_ble_evt->evt.gatts_evt.params.write.data;
    Kenneth
  • Using p_ble_evt->evt.gatts_evt.params.write.len and p_ble_evt->evt.gatts_evt.params.write.data instead of sd_ble_gatts_value_get() worked. Thanks for the help.
