Connection lost
Hi, I am trying to connect N51422 server to anther vendor's client... the devices always disconnect after 30 seconds of connection. I found that the reason of the disconnection in the N51422 is: BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION 0x13
Also, I checked the log of client and master connection form the different vendor, and I saw some events that not happen when I try to connect Nordic - other Vendor. The events are: SCPC - Client Enable Complete, SCPS - Server Enable Complete
Slave(Server): Nordic N51422 with s110_nrf51822_7.1.0 softdevice, nrf51_sdk_v6_1_0_b2ec2e6 SDK,Using the template application. Master(Client): Renesas RL78, Using my application. For some reason when I am connecting Renesas with Nordic I don't get the RBLE_SCP_Clinet_Enable event in the Master(Renesas). But I see that event when I connect Renesas to Renesas. The Renesas - Nordic connection is dropped after 30sec.
RBLE_SCP_Clinet_Enable: This function is used to enable the SCP Client role. When connecting to the SCP Server device for the first time, set con_type to RBLE_SCP_CON_CFG, and perform the configuration connection to discover service on the SCP Server device. The result is notified by the client role enable completion event RBLE_SCP_EVENT_CLIENT_ENABLE_COMP, save the obtained service information at this time. When connecting to the SCP Server device for the second or subsequent time, set con_type to RBLE_SCP_CON_NORMAL, and perform the normal connection by using saved service information. The service discovery is skipped and the Client role can be enabled in shorter time.
  • What version of SoftDevice are you using? What SDK version? Are you running one of the examples from the SDK? What central/master device are you using? What are you running on it? Please edit your question to include the information.
  • Hi, Slave(Server): Nordic N51422 with s110_nrf51822_7.1.0 softdevice, nrf51_sdk_v6_1_0_b2ec2e6 SDK,Using the template application. Master(Client): Renesas RL78, Using my application. For some reason when I am connecting Renesas with Nordic I don't get the RBLE_SCP_Clinet_Enable event in the Master(Renesas). But I see that event when I connect Renesas to Renesas. The Renesas - Nordic connection is dropped after 30sec.
