Running critical time constrained task during BLE communication
Our products are based on nrf52832 / nrf52840 chips as application mcu which run freeRTOS.
One of high priority task implements algorithm for controlling motor (using QDEC and PWM embedded modules) and it is critical time constrained task e.g. it should be run every 3 mSec.
My main concern is the mutual influence between BLE (SD) interrupts and this critical task timing.
Due to the fact that motor control is implemented as close loop control algorithm which need to be periodically calculated every 3 mSecs it seems (correct me if I am wrong) that using regular BLE communication channel shall not work.
A few solutions were considered and each of them raises specific questions:
1) Masking BLE interrupts at enter to critical task and unmasking when the critical task is yielded  - How would it influence on BLE communication?
2) Using Beacon for on way data transmission from server - Does it solve the issue of BLE SD interrupts?
3) Is there any other solution to this problem?
Thanks in advance
  • If I may summarize above discussion:
    SD has priority 0 which can't be changed (it is not exposed to application developer) and its interrupts should not be masked
    According to link connection interval (aka timing deviation) can be (1M bits PHY) between  ~ 0.5  - 2.5 mSec      ( for empty packet  and 247 Bytes data packet, respectively).
    ->  time constrained tasks can't be run as part of the application or their timing should be flexible enough for timing deviation caused by SD.
    1) Do I miss something?
    2) Does using Beacon which its transmission time can be controlled by application is practical for workaround this issue?
    3) Any other suggestion for solving this issue?
     This is absolutely correct.
    Can you please tell me more on why you think the softdevice activity will be different in the case of a Beacon? I think beacon is just a special type of advertisement and the underlying softdevice activity is similar to advertising role of the device.
    You can disable the softdevice (get disconnected) and have your motor task running and buffering the results that needs to be transmitted to the peer. Else you can use a long connection interval, in which case you will have a lot of slots between each connection interval for the motor controlling task to run and once every connection interval, the motor task will be masked by the SD. If your application can survive this, then it is currently a simple work around to just increase the connection interval to say 200ms and you will have your motor task running for 200/3 = 66 times before it is blocked once (maybe twice).
    If the above scenario does not fit your needs, then you need to have a dual core system where the BLE stack is running on one and the application has a dedicated CPU to run its time critical tasks.
  • Regarding Beacon:
    BLE communication is controlled by the client and it is a-synchronized to server tasks i.e. a-synchronized high priority interrupts when server receives client periodically communication which follow by connection interval.
    When Beacon is used it can be synchronized to idle time between critical tasks and its schedule is controlled totally by the server.
    It is one directional communication i.e. the server buffers data and broadcasts it as part of low task during critical task idle time.
    The idle time of critical task is known or atleast can be calculated per cycle and only if it long enough Beacon message can be sent by the server.
    Obviously Beacon data isn't secured and open for all observers in range. If encryption is needed it should be part of the application (not required for our specific case)
  • I had to ask my Colleague to give his opinion on this one. He said
    "If you just want to time beacon events in between the critical events. You could do that if you uses a custom advertiser, of course you will not be able to compy with the spec forr the random time component, but I think it should be ok apart from that. If you alse controls the other end you might want to use a custom protocol"
