TWI inconsistent read of slave device address location in nRF5 SDK 15.2
I am using nRF5 SDK 15.2 and the twi_sensor example to read over I2C a slave device 'WhoAmI' memory location. I first tx the slave address (0x68) and then attempt to read the memory location at 0x00. The expected value to be read back out is 0xEA (decimal 234). I am able to see this value be returned, but only after many read requests. Is there something that I may have setup wrong which may cause this?
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_sensor_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "SEGGER_RTT.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          0x68
//(0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0x00U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    ret_code_t err_code;
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    //reg[0] = LM75B_REG_TEMP;
   //m_xfer_done = false;
    //err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
    //APP_ERROR_CHECK(err_code);
    //while (m_xfer_done == false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lm75b_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
    SEGGER_RTT_printf(0, "%d ", m_sample);
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    LM75B_set_mode();
    SEGGER_RTT_WriteString(0, "Printing over RTT!\r\n");
    while (true)
        //nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
  • Typically for I2C devices, in order to read from a specific register, you would need to write the register address to the device first. However, I would recommend you to read the datasheet for the I2C device you have, as the approach may vary. Down below I have attached the code to run if your device works in the typical manner.
    First you must write the register address (0x00) to the device.
    uint8_t reg_addr = 0x00;
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, &reg_addr, 1, false);
    I can not see that you have done this.
    Next up, you can read the register as followed:
    // Read 1 byte from the specified address
    Simon
    Thanks for the reply. Unfortunately that didn't end up working, but I did figure the issue out. I'm not sure if this is consistent across all I2C slave devices, but in order to read back the address over and over the pointer address needed to be set prior to reading again. The device (ICM-20948) may not keep that register information after a read request due to volatile memory or something.
    This was the modifications that I made which worked.
    void ICM20948_set_mode(void)
        uint8_t reg_addr = 0x00; //WHO_AM_I address same as define on top.
        err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDR, &reg_addr, 1, false);
        uint8_t reg_addr = WHO_AM_I; //WHO_AM_I address same as define on top.
        //uint8_t reg_addr = ACCEL_XOUT_L; //Gyro x axis lowest 8 bits of data
          err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDR, &reg_addr, sizeof(reg_addr), false);
        /* Read 1 byte from the specified address */
        while(m_xfer_done == false);
          err_code = nrf_drv_twi_rx(&m_twi, ICM20948_ADDR, &m_sample, sizeof(m_sample));
  • Hey BendaEng,
    I am using nrf52840 with SDK 15.3. I see a lot of twi drivers and its confusing which one to use. I want to read the ICM 20948 sensor data in burst mode for my application. In the second step I want to use the tap detection in DMP, so i have to write the DMP firmware into the ICM. But my twi drivers seem to constantly return with err_code 0x11 or 0x03 errors. Please let me know which is the best twi drivers for ICM. Thanks and regards.
  • Hi Nikhilesh,
    Apologies on the late reply, I didn't see this response. I used the following TWI (I2C) driver base code set when I began figuring out how to use the ICM 20948 with the nRF52832.
    https://github.com/jrowberg/i2cdevlib/blob/master/nRF51/I2CDev/I2Cdev.cpp
    On a separate note, I found the ICM very difficult to integrate with and only ended up using the absolute orientation output (never tap detection).
    I also got a similar error when writing the DMP firmware. See the following for some potential fixes.
    https://www.invensense.com/developers/forums/topic/icm-20948-driver-firmware-upload-fails/
    https://www.invensense.com/developers/forums/topic/icm-20948-dmp/
    Hope this helps!
