Connecting.
How to delete all pairings
Connecting.
My ble_app_hrs_freertos also encounter NRF_BREAKPOINT_COND in debug after run pm_peers_delete. Please advice.
HW: PCA10056
SW:nRF5_SDK_15.2.0_9412b96
example: ble_app_hrs_freertos
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
// Board/nrf6310/ble/ble_app_hrs_rtx/main.c
* @brief Heart Rate Service Sample Application with RTX main file.
* This file contains the source code for a sample application using RTX and the
* Heart Rate service (and also Battery and Device Information services).
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_drv_clock.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "Nordic_HRM" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define BATTERY_LEVEL_MEAS_INTERVAL 2000 /**< Battery level measurement interval (ms). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL 1000 /**< Heart rate measurement interval (ms). */
#define MIN_HEART_RATE 140 /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE 300 /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT 10 /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL 300 /**< RR interval interval (ms). */
#define MIN_RR_INTERVAL 100 /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL 500 /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT 1 /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL 5000 /**< Sensor Contact Detected toggle interval (ms). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY 5000 /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY 30000 /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE 2 /**< Number of ticks to wait for the timer queue to be ready */
BLE_BAS_DEF(m_bas); /**< Battery service instance. */
BLE_HRS_DEF(m_hrs); /**< Heart rate service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_rr_interval_enabled = true; /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_heart_rate_sim_cfg; /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state; /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t m_rr_interval_sim_cfg; /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state; /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static TimerHandle_t m_battery_timer; /**< Definition of battery timer. */
static TimerHandle_t m_heart_rate_timer; /**< Definition of heart rate timer. */
static TimerHandle_t m_rr_interval_timer; /**< Definition of RR interval timer. */
static TimerHandle_t m_sensor_contact_timer; /**< Definition of sensor contact detected timer. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread; /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
bool delete_bonds = false;
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(&delete_bonds);
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("PM_EVT_BONDED_PEER_CONNECTED");
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
* in Battery Service.
static void battery_level_update(void)
ret_code_t err_code;
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer time-out.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] xTimer Handler to the timer that called this function.
* You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
UNUSED_PARAMETER(xTimer);
battery_level_update();
/**@brief Function for handling the Heart rate measurement timer time-out.
* @details This function will be called each time the heart rate measurement timer expires.
* It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
static uint32_t cnt = 0;
uint16_t heart_rate;
heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
cnt++;
err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
// Disable RR Interval recording every third heart rate measurement.
// NOTE: An application will normally not do this. It is done here just for testing generation
// of messages without RR Interval measurements.
m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer time-out.
* @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(TimerHandle_t xTimer)
if (m_rr_interval_enabled)
uint16_t rr_interval;
rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
&m_rr_interval_sim_cfg);
ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer time-out.
* @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
static bool sensor_contact_detected = false;
sensor_contact_detected = !sensor_contact_detected;
ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
m_battery_timer = xTimerCreate("BATT",
BATTERY_LEVEL_MEAS_INTERVAL,
pdTRUE,
NULL,
battery_level_meas_timeout_handler);
m_heart_rate_timer = xTimerCreate("HRT",
HEART_RATE_MEAS_INTERVAL,
pdTRUE,
NULL,
heart_rate_meas_timeout_handler);
m_rr_interval_timer = xTimerCreate("RRT",
RR_INTERVAL_INTERVAL,
pdTRUE,
NULL,
rr_interval_timeout_handler);
m_sensor_contact_timer = xTimerCreate("SCT",
SENSOR_CONTACT_DETECTED_INTERVAL,
pdTRUE,
NULL,
sensor_contact_detected_timeout_handler);
/* Error checking */
if ( (NULL == m_battery_timer)
|| (NULL == m_heart_rate_timer)
|| (NULL == m_rr_interval_timer)
|| (NULL == m_sensor_contact_timer) )
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
* @details Initialize the Heart Rate, Battery and Device Information services.
ble_hrs_init_t hrs_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
uint8_t body_sensor_location;
// Initialize Heart Rate Service.
body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
memset(&hrs_init, 0, sizeof(hrs_init));
hrs_init.evt_handler = NULL;
hrs_init.is_sensor_contact_supported = true;
hrs_init.p_body_sensor_location = &body_sensor_location;
// Here the sec level for the Heart Rate Service can be changed/increased.
hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
hrs_init.bsl_rd_sec = SEC_OPEN;
err_code = ble_hrs_init(&m_hrs, &hrs_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
bas_init.bl_rd_sec = SEC_OPEN;
bas_init.bl_cccd_wr_sec = SEC_OPEN;
bas_init.bl_report_rd_sec = SEC_OPEN;
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
dis_init.dis_char_rd_sec = SEC_OPEN;
err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators. */
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
m_heart_rate_sim_cfg.min = MIN_HEART_RATE;
m_heart_rate_sim_cfg.max = MAX_HEART_RATE;
m_heart_rate_sim_cfg.incr = HEART_RATE_INCREMENT;
m_heart_rate_sim_cfg.start_at_max = false;
sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
m_rr_interval_sim_cfg.min = MIN_RR_INTERVAL;
m_rr_interval_sim_cfg.max = MAX_RR_INTERVAL;
m_rr_interval_sim_cfg.incr = RR_INTERVAL_INCREMENT;
m_rr_interval_sim_cfg.start_at_max = false;
sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
* @details Timers are run after the scheduler has started.
static void application_timers_start(void)
// Start application timers.
if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for initializing the Connection Parameters module. */
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = m_hrs.hrm_handles.cccd_handle;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
/**@brief Clear bond information from persistent storage. */
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
delete_bonds();
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization. */
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Function for initializing the Advertising functionality. */
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void log_init(void)
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for starting advertising. */
bool erase_bonds = *(bool*)p_erase_bonds;
if (erase_bonds)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
* @details This thread is responsible for processing log entries if logs are deferred.
* Thread flushes all log entries and suspends. It is resumed by idle task hook.
* @param[in] arg Pointer used for passing some arbitrary information (context) from the
* osThreadCreate() call to the thread.
static void logger_thread(void * arg)
UNUSED_PARAMETER(arg);
while (1)
NRF_LOG_FLUSH();
vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
* @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
ret_code_t err_code = nrf_drv_clock_init();
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize modules.
log_init();
clock_init();
// Do not start any interrupt that uses system functions before system initialisation.
// The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
// Start execution.
if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
// Activate deep sleep mode.
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
// Configure and initialize the BLE stack.
ble_stack_init();
timers_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
application_timers_start();
// Create a FreeRTOS task for the BLE stack.
// The task will run advertising_start() before entering its loop.
nrf_sdh_freertos_init(advertising_start, &erase_bonds);
NRF_LOG_INFO("HRS FreeRTOS example started.");
// Start FreeRTOS scheduler.
vTaskStartScheduler();
for (;;)
APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
What's the return code from pm_peers_delete?
I checked, it didn't even completed progress through the whole pm_peers_delete function. The NRF_BREAKPOINT_COND happens when evt_send(&pm_delete_all_evt) is called.
My device already pair with the phone via nrf connect mobile app. Not sure why it shown no peer id
evt_send calls the event handler of the first event handler registered through pm_register (first loop), this might be the function pointer in m_evt_handlers[0].
That event handler is the next clue of our mystery. I'm guessing that it contains the APP_ERROR_CHECK that processed a non-NRF_SUCCSESS return code, thereby calling the error handler.
Thanks. What should I do next, I kinda out of idea about this. As the whole driver code is like a black box to me.
Here is the debug crush disassembly.
--- app_button.c -- 152 ------------------------------------
VERIFY_SUCCESS(err_code);
// Save configuration.
mp_buttons = p_buttons;
4B1A ldr r3, =0x20005E38 <mp_buttons>
601E str r6, [r3]
--- app_button.c -- 157 ------------------------------------
m_button_count = button_count;
4B1A ldr r3, =0x20005DFC <m_button_count>
701D strb r5, [r3]
--- app_button.c -- 158 ------------------------------------
m_detection_delay = detection_delay;
4B1A ldr r3, =0x20005E00 <m_detection_delay>
601C str r4, [r3]
--- app_button.c -- 159 ------------------------------------
m_pin_state = 0;
2200 movs r2, #0
2300 movs r3, #0
4919 ldr r1, =0x20005E28 <m_pin_state>
E9C12300 strd r2, r3, [r1, #0]
--- app_button.c -- 161 ------------------------------------
m_pin_transition = 0;
4918 ldr r1, =0x20005E30 <m_pin_transition>
--- app_button.c -- 162 ------------------------------------
while (button_count--)
1E6C subs r4, r5, #1
B2E4 uxtb r4, r4
B1D5 cbz r5, 0x0002749E
--- app_button.c -- 164 ------------------------------------
app_button_cfg_t const * p_btn = &p_buttons[button_count];
EB0603C4 add.w r3, r6, r4, lsl #3
--- app_button.c -- 166 ------------------------------------
#if defined(BUTTON_HIGH_ACCURACY_ENABLED) && (BUTTON_HIGH_ACCURACY_ENABLED == 1)
nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(p_btn->hi_accuracy);
#else
nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
2200 movs r2, #0
F88D2006 strb.w r2, [sp, #6]
2203 movs r2, #3
F88D2004 strb.w r2, [sp, #4]
--- app_button.c -- 171 ------------------------------------
config.pull = p_btn->pull_cfg;
789B ldrb r3, [r3, #2]
F88D3005 strb.w r3, [sp, #5]
--- app_button.c -- 173 ------------------------------------
err_code = nrf_drv_gpiote_in_init(p_btn->pin_no, &config, gpiote_event_handler);
4A11 ldr r2, =0x00027391
A901 add r1, sp, #4
F8160034 ldrb.w r0, [r6, r4, lsl #3]
F004FC45 bl 0x0002BD14 <nrfx_gpiote_in_init>
--- app_button.c -- 175 ------------------------------------
4603 mov r3, r0
B968 cbnz r0, 0x000274AA
--- app_button.c -- 163 ------------------------------------
4625 mov r5, r4
E7E7 b 0x00027462
--- app_button.c -- 151 ------------------------------------
F004FBF3 bl 0x0002BC7C <nrfx_gpiote_init>
4603 mov r3, r0
2800 cmp r0, #0
D0D4 beq 0x00027446
E005 b 0x000274AA
// Create polling timer.
return app_timer_create(&m_detection_delay_timer_id,
4A0A ldr r2, =0x0002729D
2100 movs r1, #0
480A ldr r0, =0x0003409C <m_detection_delay_timer_id>
F000F87C bl 0x000275A0 <app_timer_create>
4603 mov r3, r0
--- app_button.c -- 180 ------------------------------------
APP_TIMER_MODE_SINGLE_SHOT,
detection_delay_timeout_handler);
4618 mov r0, r3
B002 add sp, sp, #8
BD70 pop {r4-r6, pc}
20005E38 .word 0x20005E38
20005DFC .word 0x20005DFC
20005E00 .word 0x20005E00
20005E28 .word 0x20005E28
20005E30 .word 0x20005E30
00027391 .word 0x00027391
0002729D .word 0x0002729D
0003409C .word 0x0003409C
--- app_button.c -- 183 ------------------------------------
uint32_t app_button_enable(void)
B510 push {r4, lr}
--- app_button.c -- 186 ------------------------------------
ASSERT(mp_buttons);
uint32_t i;
for (i = 0; i < m_button_count; i++)
2400 movs r4, #0
E007 b 0x000274E6
--- app_button.c -- 190 ------------------------------------
nrf_drv_gpiote_in_event_enable(mp_buttons[i].pin_no, true);
4B07 ldr r3, =0x20005E38 <mp_buttons>
681B ldr r3, [r3]
2101 movs r1, #1
F8130034 ldrb.w r0, [r3, r4, lsl #3]
F004FC94 bl 0x0002BE0C <nrfx_gpiote_in_event_enable>
--- app_button.c -- 189 ------------------------------------
3401 adds r4, #1
4B04 ldr r3, =0x20005DFC <m_button_count>
781B ldrb r3, [r3]
429C cmp r4, r3
D3F3 bcc 0x000274D6
--- app_button.c -- 191 ------------------------------------
return NRF_SUCCESS;
2000 movs r0, #0
BD10 pop {r4, pc}
BF00 nop
--- app_error.c -- 61 --------------------------------------
* @param[in] line_num Line number where the handler is called.
* @param[in] p_file_name Pointer to the file name.
void app_error_handler_bare(ret_code_t error_code)
B500 push {lr}
B085 sub sp, sp, #20
--- app_error.c -- 66 --------------------------------------
error_info_t error_info =
2100 movs r1, #0
9101 str r1, [sp, #4]
9102 str r1, [sp, #8]
9003 str r0, [sp, #12]
--- app_error.c -- 69 --------------------------------------
.p_file_name = NULL,
.err_code = error_code,
app_error_fault_handler(NRF_FAULT_ID_SDK_ERROR, 0, (uint32_t)(&error_info));
AA01 add r2, sp, #4
F2440001 movw r0, #0x4001
F000F803 bl 0x00027518 <app_error_fault_handler>
--- app_error.c -- 74 --------------------------------------
UNUSED_VARIABLE(error_info);
B005 add sp, sp, #20
F85DFB04 pop.w {pc}
--- app_error_weak.c -- 53 ---------------------------------
* Function is implemented as weak so that it can be overwritten by custom application error handler
* when needed.
__WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
B510 push {r4, lr}
--- cmsis_gcc.h -- 67 --------------------------------------
Can only be executed in Privileged modes.
__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
__ASM volatile ("cpsid i" : : : "memory");
B672 cpsid i
--- app_error_weak.c -- 55 ---------------------------------
__disable_irq();
NRF_LOG_FINAL_FLUSH();
F7FFFD92 bl 0x00027044 <nrf_log_panic>
--- app_error_weak.c -- 59 ---------------------------------
F7FFF96E bl 0x00026800 <nrf_log_frontend_dequeue>
2800 cmp r0, #0
D1FB bne 0x00027520
--- app_error_weak.c -- 60 ---------------------------------
#ifndef DEBUG
NRF_LOG_ERROR("Fatal error");
4B10 ldr r3, =0x00033E80 <__cli_command_end__>
4C11 ldr r4, =0x00033EA8 <m_nrf_log_app_logs_data_const>
1AE4 subs r4, r4, r3
08E4 lsrs r4, r4, #3
0424 lsls r4, r4, #16
4910 ldr r1, =0x000340A0
F0440001 orr r0, r4, #1
F7FFFAA4 bl 0x00026A84 <nrf_log_frontend_std_0>
--- app_error_weak.c -- 96 ---------------------------------
NRF_BREAKPOINT_COND;
4B0E ldr r3, =0xE000EDF0
681B ldr r3, [r3]
F0130F01 tst r3, #1
D000 beq 0x00027548
--- app_error_weak.c -- 100 --------------------------------
BE00 bkpt #0
--- app_error_weak.c -- 101 --------------------------------
// On assert, the system can only recover with a reset.
#ifndef DEBUG
NRF_LOG_WARNING("System reset");
490C ldr r1, =0x000340AC
F0440002 orr r0, r4, #2
F7FFFA99 bl 0x00026A84 <nrf_log_frontend_std_0>
--- cmsis_gcc.h -- 425 -------------------------------------
It completes when all explicit memory accesses before this instruction complete.
__attribute__((always_inline)) __STATIC_INLINE void __DSB(void)
__ASM volatile ("dsb 0xF":::"memory");
F3BF8F4F dsb sy
--- core_cm4.h -- 1791 -------------------------------------
__DSB(); /* Ensure all outstanding memory accesses included
buffered write are completed before reset */
SCB->AIRCR = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
(SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
490A ldr r1, =0xE000ED00
68CA ldr r2, [r1, #12]
F40262E0 and r2, r2, #0x700
4B09 ldr r3, =0x05FA0004
4313 orrs r3, r2
--- core_cm4.h -- 1794 -------------------------------------
60CB str r3, [r1, #12]
F3BF8F4F dsb sy
--- cmsis_gcc.h -- 375 -------------------------------------
__ASM volatile ("nop");
BF00 nop
E7FD b 0x00027568
00033E80 .word 0x00033E80
00033EA8 .word 0x00033EA8
000340A0 .word 0x000340A0
E000EDF0 .word 0xE000EDF0
000340AC .word 0x000340AC
E000ED00 .word 0xE000ED00
05FA0004 .word 0x05FA0004
--- app_timer_freertos.c -- 99 -----------------------------
* It gets our parameter from timer data and sends it to user function.
* @param[in] xTimer Timer handler
static void app_timer_callback(TimerHandle_t xTimer)
B508 push {r3, lr}
--- app_timer_freertos.c -- 104 ----------------------------
app_timer_info_t * pinfo = (app_timer_info_t*)(pvTimerGetTimerID(xTimer));
F004F868 bl 0x0002B65E <pvTimerGetTimerID>
--- app_timer_freertos.c -- 105 ----------------------------
ASSERT(pinfo->osHandle == xTimer);
ASSERT(pinfo->func != NULL);
if (pinfo->active)
7B03 ldrb r3, [r0, #12]
B903 cbnz r3, 0x00027594
BD08 pop {r3, pc}
--- app_timer_freertos.c -- 109 ----------------------------
pinfo->func(pinfo->argument);
6883 ldr r3, [r0, #8]
6800 ldr r0, [r0]
4798 blx r3
--- app_timer_freertos.c -- 110 ----------------------------
E7FA b 0x00027592
--- app_timer_freertos.c -- 112 ----------------------------
uint32_t app_timer_init(void)
return NRF_SUCCESS;
2000 movs r0, #0
4770 bx lr
--- app_timer_freertos.c -- 118 ----------------------------
uint32_t app_timer_create(app_timer_id_t const * p_timer_id,
app_timer_mode_t mode,
app_timer_timeout_handler_t timeout_handler)
B570 push {r4-r6, lr}
B082 sub sp, sp, #8
--- app_timer_freertos.c -- 123 ----------------------------
app_timer_info_t * pinfo = (app_timer_info_t*)(*p_timer_id);
6804 ldr r4, [r0]
--- app_timer_freertos.c -- 124 ----------------------------
uint32_t err_code = NRF_SUCCESS;
unsigned long timer_mode;
if ((timeout_handler == NULL) || (p_timer_id == NULL))
B30A cbz r2, 0x000275EC
4615 mov r5, r2
--- app_timer_freertos.c -- 127 ----------------------------
B308 cbz r0, 0x000275F0
--- app_timer_freertos.c -- 128 ----------------------------
return NRF_ERROR_INVALID_PARAM;
if (pinfo->active)
7B23 ldrb r3, [r4, #12]
B113 cbz r3, 0x000275B6
--- app_timer_freertos.c -- 132 ----------------------------
2008 movs r0, #8
--- app_timer_freertos.c -- 155 ----------------------------
return err_code;
B002 add sp, sp, #8
--- app_timer_freertos.c -- 136 ----------------------------
if (pinfo->osHandle == NULL)
6863 ldr r3, [r4, #4]
B10B cbz r3, 0x000275BE
--- app_timer_freertos.c -- 151 ----------------------------
/* Timer cannot be reinitialized using FreeRTOS API */
2008 movs r0, #8
E7F9 b 0x000275B2
460E mov r6, r1
--- app_timer_freertos.c -- 139 ----------------------------
memset(pinfo, 0, sizeof(app_timer_info_t));
2210 movs r2, #16
2100 movs r1, #0
4620 mov r0, r4
F00CFBA5 bl 0x00033D14 <memset>
--- app_timer_freertos.c -- 140 ----------------------------
if (mode == APP_TIMER_MODE_SINGLE_SHOT)
B96E cbnz r6, 0x000275E8
--- app_timer_freertos.c -- 142 ----------------------------
timer_mode = pdFALSE;
2200 movs r2, #0
--- app_timer_freertos.c -- 143 ----------------------------
timer_mode = pdTRUE;
pinfo->func = timeout_handler;
60A5 str r5, [r4, #8]
--- app_timer_freertos.c -- 147 ----------------------------
pinfo->osHandle = xTimerCreate(" ", 1000, timer_mode, pinfo, app_timer_callback);
4B09 ldr r3, =0x00027589
9300 str r3, [sp]
4623 mov r3, r4
F44F717A mov.w r1, #0x3E8
4808 ldr r0, =0x00034034
F003FED4 bl 0x0002B388 <xTimerCreate>
6060 str r0, [r4, #4]
--- app_timer_freertos.c -- 148 ----------------------------
B138 cbz r0, 0x000275F4
2000 movs r0, #0
E7E4 b 0x000275B2
2201 movs r2, #1
E7F0 b 0x000275CE
--- app_timer_freertos.c -- 129 ----------------------------
2007 movs r0, #7
E7E0 b 0x000275B2
2007 movs r0, #7
E7DE b 0x000275B2
--- app_timer_freertos.c -- 146 ----------------------------
err_code = NRF_ERROR_NULL;
200E movs r0, #14
E7DC b 0x000275B2
00027589 .word 0x00027589
00034034 .word 0x00034034
--- app_timer_freertos.c -- 159 ----------------------------
uint32_t app_timer_start(app_timer_id_t timer_id, uint32_t timeout_ticks, void * p_context)
B5F0 push {r4-r7, lr}
--- app_timer_freertos.c -- 164 ----------------------------
app_timer_info_t * pinfo = (app_timer_info_t*)(timer_id);
TimerHandle_t hTimer = pinfo->osHandle;
6847 ldr r7, [r0, #4]
--- app_timer_freertos.c -- 166 ----------------------------
if (hTimer == NULL)
2F00 cmp r7, #0
D053 beq 0x000276B2
4614 mov r4, r2
460E mov r6, r1
4605 mov r5, r0
--- app_timer_freertos.c -- 168 ----------------------------
if (pinfo->active && (xTimerIsTimerActive(hTimer) != pdFALSE))
B993 cbnz r3, 0x0002763A
--- app_timer_freertos.c -- 173 ----------------------------
// Timer already running - exit silently
return NRF_SUCCESS;
pinfo->argument = p_context;
602C str r4, [r5]
--- cmsis_gcc.h -- 105 -------------------------------------
__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_IPSR(void)
uint32_t result;
__ASM volatile ("MRS %0, ipsr" : "=r" (result) );
F3EF8305 mrs r3, ipsr
--- app_timer_freertos.c -- 175 ----------------------------
if (__get_IPSR() != 0)
B383 cbz r3, 0x0002767E
--- app_timer_freertos.c -- 180 ----------------------------
BaseType_t yieldReq = pdFALSE;
2200 movs r2, #0
AB04 add r3, sp, #16
F8432D04 str r2, [r3, #-4]!
--- app_timer_freertos.c -- 182 ----------------------------
if (xTimerChangePeriodFromISR(hTimer, timeout_ticks, &yieldReq) != pdPASS)
9200 str r2, [sp]
4632 mov r2, r6
2109 movs r1, #9
4638 mov r0, r7
F003FEC6 bl 0x0002B3BC <xTimerGenericCommand>
2801 cmp r0, #1
D009 beq 0x00027648
--- app_timer_freertos.c -- 183 ----------------------------
return NRF_ERROR_NO_MEM;
2004 movs r0, #4
--- app_timer_freertos.c -- 205 ----------------------------
pinfo->active = true;
return NRF_SUCCESS;
BDF0 pop {r4-r7, pc}
--- app_timer_freertos.c -- 171 ----------------------------
4638 mov r0, r7
F004F803 bl 0x0002B646 <xTimerIsTimerActive>
2800 cmp r0, #0
D0E7 beq 0x00027614
--- app_timer_freertos.c -- 172 ----------------------------
return NRF_SUCCESS;
2000 movs r0, #0Thanks. What should I do next, I kinda out of idea about this. As the whole driver code is like a black box to me.
601E str r6, [r3]
701D strb r5, [r3]
601C str r4, [r3]
m_pin_state = 0;
2200 movs r2, #0
2300 movs r3, #0
B2E4 uxtb r4, r4
#else
2200 movs r2, #0
2203 movs r2, #3
A901 add r1, sp, #4
4603 mov r3, r0
4625 mov r5, r4
E7E7 b 0x00027462
4603 mov r3, r0
2800 cmp r0, #0
D0D4 beq 0x00027446
E005 b 0x000274AA
2100 movs r1, #0
4603 mov r3, r0
4618 mov r0, r3
B002 add sp, sp, #8
B510 push {r4, lr}
ASSERT(mp_buttons);
uint32_t i;
2400 movs r4, #0
E007 b 0x000274E6
681B ldr r3, [r3]
2101 movs r1, #1
3401 adds r4, #1
781B ldrb r3, [r3]
429C cmp r4, r3
D3F3 bcc 0x000274D6
return NRF_SUCCESS;
2000 movs r0, #0
BD10 pop {r4, pc}
BF00 nop
B500 push {lr}
2100 movs r1, #0
AA01 add r2, sp, #4
F85DFB04 pop.w {pc}
* when needed.
B510 push {r4, lr}
B672 cpsid i
__disable_irq();
2800 cmp r0, #0
D1FB bne 0x00027520
#ifndef DEBUG
681B ldr r3, [r3]
F0130F01 tst r3, #1
D000 beq 0x00027548
BE00 bkpt #0
#ifndef DEBUG
F3BF8F4F dsb sy
4313 orrs r3, r2
F3BF8F4F dsb sy
BF00 nop
E7FD b 0x00027568
B508 push {r3, lr}
if (pinfo->active)
BD08 pop {r3, pc}
6800 ldr r0, [r0]
4798 blx r3
E7FA b 0x00027592
return NRF_SUCCESS;
2000 movs r0, #0
4770 bx lr
B082 sub sp, sp, #8
6804 ldr r4, [r0]
4615 mov r5, r2
if (pinfo->active)
2008 movs r0, #8
return err_code;
B002 add sp, sp, #8
2008 movs r0, #8
E7F9 b 0x000275B2
460E mov r6, r1
2210 movs r2, #16
2100 movs r1, #0
4620 mov r0, r4
2200 movs r2, #0
9300 str r3, [sp]
4623 mov r3, r4
2000 movs r0, #0
E7E4 b 0x000275B2
2201 movs r2, #1
E7F0 b 0x000275CE
2007 movs r0, #7
E7E0 b 0x000275B2
2007 movs r0, #7
E7DE b 0x000275B2
200E movs r0, #14
E7DC b 0x000275B2
if (hTimer == NULL)
2F00 cmp r7, #0
D053 beq 0x000276B2
4614 mov r4, r2
460E mov r6, r1
4605 mov r5, r0
return NRF_SUCCESS;
602C str r4, [r5]
uint32_t result;
2200 movs r2, #0
9200 str r2, [sp]
4632 mov r2, r6
2109 movs r1, #9
4638 mov r0, r7
2801 cmp r0, #1
D009 beq 0x00027648
2004 movs r0, #4
return NRF_SUCCESS;
4638 mov r0, r7
2800 cmp r0, #0
D0E7 beq 0x00027614
return NRF_SUCCESS;
2000 movs r0, #0
