PWM PPI timer_handler
Hi,everyone I want to make out 4 channel PWM with PPI and two timers , PPI configuration like this,
/* Configure PPI channel 0 to toggle PWM_OUTPUT_PIN on every Timer 2 COMPARE[0] match. */
NRF_PPI->CH[0].EEP  = (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[0];
NRF_PPI->CH[0].TEP  = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
/* Configure PPI channel 1 to toggle PWM_OUTPUT_PIN on every Timer 2 COMPARE[1] match. */
NRF_PPI->CH[1].EEP  = (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[1];
NRF_PPI->CH[1].TEP  = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
    /* Configure PPI channel 2 to toggle PWM_OUTPUT_PIN on every Timer 2 COMPARE[0] match. */
NRF_PPI->CH[2].EEP  = (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[0];
NRF_PPI->CH[2].TEP  = (uint32_t)&NRF_GPIOTE->TASKS_OUT[1];
/* Configure PPI channel 3 to toggle PWM_OUTPUT_PIN on every Timer 2 COMPARE[2] match. */
NRF_PPI->CH[3].EEP  = (uint32_t)&NRF_TIMER1->EVENTS_COMPARE[2];
NRF_PPI->CH[3].TEP  = (uint32_t)&NRF_GPIOTE->TASKS_OUT[1];
is this right?
another queston is when I use sd_nvic_EnableIRQ , timer_handler function can not be called, but when I use NVIC_EnableIRQ, the EK board's blue tooth function stop working;
here is the code:
      sd_nvic_SetPriority(TIMER1_IRQn,3);
  sd_nvic_SetPriority(TIMER2_IRQn,3);
// Enable interrupt on Timer
//NVIC_EnableIRQ(TIMER1_IRQn);
//NVIC_EnableIRQ(TIMER2_IRQn);
  sd_nvic_EnableIRQ(TIMER1_IRQn);
  sd_nvic_EnableIRQ(TIMER2_IRQn);
     __enable_irq();
  • In your code you are only using TIMER1. If you want to use two different timers (as you say) to control two PWM signals, the ppi_init() would look something linke this:
    static void ppi_init(void)
    /* Configure PPI channel 0 to toggle PWM_OUTPUT_PIN1 on every Timer 1 COMPARE[0] match. */
    /* Configure PPI channel 1 to toggle PWM_OUTPUT_PIN1 on every Timer 1 COMPARE[1] match. */
    /* Configure PPI channel 2 to toggle PWM_OUTPUT_PIN2 on every Timer 2 COMPARE[0] match. */
    NRF_PPI->CH[2].EEP  = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[0];
    /* Configure PPI channel 3 to toggle PWM_OUTPUT_PIN2 on every Timer 2 COMPARE[1] match. */
    NRF_PPI->CH[3].EEP  = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[1];
    /* Enable only PPI channels 0 - 3. */
    NRF_PPI->CHEN       = (PPI_CHEN_CH0_Enabled << PPI_CHEN_CH0_Pos) |
    			          (PPI_CHEN_CH1_Enabled << PPI_CHEN_CH1_Pos) |
    				      (PPI_CHEN_CH2_Enabled << PPI_CHEN_CH2_Pos) |
                          (PPI_CHEN_CH3_Enabled << PPI_CHEN_CH3_Pos);
    When SoftDevice is enabled you must use sd_nvic_EnableIRQ(). If you would like to use the PWM library with SoftDevice you should check out this project on GitHub: github.com/.../nrf51-pwm-library
  • yes,I use two timers , I want to make sure if one EVENTS_COMPARE[] can trigger several TASKS_OUT[],through PPI channels;
    secondly, as following
        //    NVIC_EnableIRQ(TIMER1_IRQn);
        //    NVIC_EnableIRQ(TIMER2_IRQn);
         //   __enable_irq();
         //  NRF_POWER->TASKS_CONSTLAT = 1;
    when I use NVIC_EnableIRQ, the stack becomes unstable,I cannot discover the device in my phone APP, but the PWM output is OK(My project aim to generating PWM,which can be adjusted by my phone);
    when I use sd_nvic_EnableIRQ ,I can connect to the device and send data, but the pwm output miss, and program can not enter the timers' handler functions, sometime enter HardFault_Handler.
  • Did you check out this project? github.com/.../nrf51-pwm-library
    It should work together with the SoftDevice.
  • Sure, I have , I have modified my project according to it ,but that does not work; the main function of my project as blow:
    timer_gpiote_init();//config ppi channel ; gpiote and timer_event
    //    __enable_irq();
    // Start the timer.
    NRF_TIMER1->TASKS_START = 1;
    NRF_TIMER2->TASKS_START = 1;
    // Initialize
    leds_init();
    app_timers_init();
    gpiote_init();
    buttons_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    sec_params_init();
    // Start execution
    app_timers_start();
    advertising_start();
    // Enter main loop
    for (;;)
       app_sched_execute();
       power_manage();
  • here is the ppi configuration
    uint8_t i;
    sd_ppi_channel_assign(0, &NRF_TIMER1->EVENTS_COMPARE[0], &NRF_GPIOTE->TASKS_OUT[0]); sd_ppi_channel_assign(1, &NRF_TIMER1->EVENTS_COMPARE[1], &NRF_GPIOTE->TASKS_OUT[0]); sd_ppi_channel_assign(2, &NRF_TIMER1->EVENTS_COMPARE[2], &NRF_GPIOTE->TASKS_OUT[1]); sd_ppi_channel_assign(3, &NRF_TIMER1->EVENTS_COMPARE[3], &NRF_GPIOTE->TASKS_OUT[1]); sd_ppi_channel_assign(4, &NRF_TIMER2->EVENTS_COMPARE[0], &NRF_GPIOTE->TASKS_OUT[2]); sd_ppi_channel_assign(5, &NRF_TIMER2->EVENTS_COMPARE[1], &NRF_GPIOTE->TASKS_OUT[2]); sd_ppi_channel_assign(6, &NRF_TIMER2->EVENTS_COMPARE[2], &NRF_GPIOTE->TASKS_OUT[3]); sd_ppi_channel_assign(7, &NRF_TIMER2->EVENTS_COMPARE[3], &NRF_GPIOTE->TASKS_OUT[3]); for(i=0;i<8;i++) { sd_ppi_channel_enable_set(1 << i); }
