Porting SSD1306 for Oled
I need to port ssd1306 library for oled to nrf51822.
so i tested following code. but it's not worked.
main(){
    if (!twi_master_init())
        return false;
     ssd1306_init();
static bool ssd1306_lcd_set_instruction(uint8_t instr)
    nrf_delay_us(10000);
    data_buffer[0] = 0x00;
    data_buffer[1] = instr;
    return twi_master_transfer(SSD1306_SA << 1, data_buffer, 2, TWI_ISSUE_STOP);
bool ssd1306_init(void)
if (!ssd1306_lcd_set_instruction(0xAE)) <- not worked , returns false
    return false;
	if (!ssd1306_lcd_set_instruction(0x00))
    return false;
	if (!ssd1306_lcd_set_instruction(0x10))
    return false;
	if (!ssd1306_lcd_set_instruction(0x40))
    return false;
	if (!ssd1306_lcd_set_instruction(0x81))
    return false;
	if (!ssd1306_lcd_set_instruction(0xCF))
    return false;
	if (!ssd1306_lcd_set_instruction(0xA1))
    return false;
	if (!ssd1306_lcd_set_instruction(0xC8))
    return false;
	if (!ssd1306_lcd_set_instruction(0xA6))
    return false;
	if (!ssd1306_lcd_set_instruction(0xA8))
    return false;
	if (!ssd1306_lcd_set_instruction(0x3F))
    return false;
	if (!ssd1306_lcd_set_instruction(0xD3))
    return false;
    return false;
	if (!ssd1306_lcd_set_instruction(0xD5))
    return false;
	if (!ssd1306_lcd_set_instruction(0x80))
    return false;
	if (!ssd1306_lcd_set_instruction(0xD9))
    return false;
	if (!ssd1306_lcd_set_instruction(0xF1))
    return false;
	if (!ssd1306_lcd_set_instruction(0xDA))
    return false;
	if (!ssd1306_lcd_set_instruction(0x12))
    return false;
	if (!ssd1306_lcd_set_instruction(0xDB))
    return false;
    return false;
	if (!ssd1306_lcd_set_instruction(0x20))
    return false;
	if (!ssd1306_lcd_set_instruction(0x02))
    return false;
	if (!ssd1306_lcd_set_instruction(0x8D))
    return false;
	if (!ssd1306_lcd_set_instruction(0x14))
    return false;
	if (!ssd1306_lcd_set_instruction(0xA4))
    return false;
    return false;
return ssd1306_lcd_set_instruction(0xAF);
Another question. How can I draw screen? Thank you all..
void ssd1306_fillscreen(uint8_t fill_Data)
uint8_t m,n;
for(m=0;m<8;m++)
	ssd1306_lcd_set_instruction(0xb0+m);	//page0-page1
	ssd1306_lcd_set_instruction(0x00);		//low column start address
	ssd1306_lcd_set_instruction(0x10);		//high column start address
	nrf_delay_us(1000);
	data_buffer[0] = DATA_SET; // 0x40
	twi_master_transfer(SSD1306_SA << 1, data_buffer, 1, TWI_DONT_ISSUE_STOP);
	for(n=0;n<127;n++)
		data_buffer[0] = fill_Data;
		//ssd1306_send_byte(fill_Data);
	twi_master_transfer(SSD1306_SA << 1, data_buffer, 1, TWI_ISSUE_STOP);
	//ssd1306_send_data_stop();
