Hi all. I am trying to work out if the following is possible;
At the moment I have setup a freq counter (analog signal) on the nRF52832. It uses the comp to detect up crossing events, and this is liked to a timer in counter mode via a PPI channel. A second timer (100mS) stops the counter, so I basically I end up with a freq count / 10.
Would it be possible to somehow use PPI to move the count value into an array somewhere, so basically every 100mS I can reset the counter via PPI, but also move the result to an array? This way I could monitor a signal continuously for freq change,
I could use the counters other CC registers, but there are only 4 so could only collect 4 values with my current knowledge. It would be good to be able to keep collecting the readings somehow.
Not sure if easyDMA can help with this?
Thanks
Phil
