Hello ,
Que 1 :I want to Merge Client and Provisioner Firmware is possible..?
Que 2:Multiple provisioner can i define in same moudle.
Que 3:BLE MESH Network ,How many Provisioner work in same network..?
Regard's
Nikunj
Hello ,
Regard's
Nikunj
You can either add provisioner functionality to client firmware or the other way around. I suggest you have a look at the access_setup() function in the main file.
Hello Mttrinh,
I have add client functionality in provisioner FW. Device Successfully Configure in Mesh network But when I send Msg to the server function return Error Code 7(NRF_ERROR_INVALID_PARAM
I have seen in MESH_SDK_1.1
if (access_flash_config_load()) //Recover access layer configuration from flash.//All models have to be added before this function is called.
m_configured_devices = configured_devices_count_get();
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "m_configured_devices:%d\n",m_configured_devices);
/* Bind the keys to the health client. */
ERROR_CHECK(access_model_application_bind(m_health_client.model_handle, m_appkey_handle));
ERROR_CHECK(access_model_publish_application_set(m_health_client.model_handle, m_appkey_handle));//health client
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_model_publish_application_set\n");
/* Bind the keys to the Simple OnOff clients. */
for (uint32_t i = 0; i < SERVER_COUNT; ++i)
ERROR_CHECK(access_model_application_bind(m_clients[i].model_handle, m_appkey_handle));//Bind appkey with Model Handle
ERROR_CHECK(access_model_publish_application_set(m_clients[i].model_handle, m_appkey_handle));//publish Appkey With model
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_model_publish_application_set All Server\n");
ERROR_CHECK(access_model_application_bind(m_clients[GROUP_CLIENT_INDEX].model_handle, m_appkey_handle));
ERROR_CHECK(access_model_publish_application_set(m_clients[GROUP_CLIENT_INDEX].model_handle, m_appkey_handle));//Client Group
ERROR_CHECK(access_model_publish_address_set(m_clients[GROUP_CLIENT_INDEX].model_handle, m_group_handle));
access_flash_config_store();//Store the current state of access layer - information related to element and model configuration - in non volatile memory.
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_flash_config_store current state\n");
In BLE MESH_3.0
/* Binds the local models correctly with the desired keys */ void app_default_models_bind_setup(void) { /* Bind health client to App key, and configure publication key */ ERROR_CHECK(access_model_application_bind(m_dev_handles.m_health_client_instance.model_handle, m_dev_handles.m_appkey_handle)); ERROR_CHECK(access_model_publish_application_set(m_dev_handles.m_health_client_instance.model_handle, m_dev_handles.m_appkey_handle)); /* Bind self-config server to the self device key */ ERROR_CHECK(config_server_bind(m_dev_handles.m_self_devkey_handle)); }
Can you help me figure out what i am doing wrong?
Thanks
Nikunj
m_model_pool[handle].model_info.publish_appkey_handle = 0xFFFF
m_model_pool[handle].model_info.publish_address_handle = 0xFFFF so I got an error 7 how to resolve this Error.
Please reply me ASAP
I assume you get this error code from access_model_reliable_publish() function? You will get this error code(NRF_ERROR_INVALID_PARAM) as a return code if your model is not bound to an application key, publish address not set or wrong opcode. Can you check that your parameters are correct?
