Dear DevZone,
I'm new to the nRF52-DK and Nordic in general. I'm trying to set up an nRF52-DK to use with nRF Sniffer, and not having any success.
I have tried following the installation instructions in the nRF Sniffer User Guide v2.2, but get stuck very quickly. I have installed WireShark V2.6.6 and Python 2.7, and installed pyserial as directed by the User Guide.
I have two nRF52-DK boards, and have programmed one with the HRM demo, and it works with nRF Toolbox just fine.
I also used Segger Embedded Studio and programmed the sniffer_pca10040_1c2a221.hex onto the second nRF52-DK. After cycling power, LED1 blinks frequently, which I assume means that it is watching packets go by and trying to report them over the JLINK CDC COM port. I should note that when I connect this DK via the USB cable, it does not show up as a mass storage device like the other nRF52-DK does.
I have copied what I believe are the necessary files to C:\Program Files\Wireshark\extcap as shown below:
However, I am not sure that the nrf_sniffer.bat file is configured correctly. My Python 2.7 installation is in C:\Python27, and this directory is NOT on my PATH:
@echo off
python "%~dp0nrf_sniffer.py" %*
In section 2.3.1, there are instructions to Enable the Sniffer, but I do not see Interface Toolbars, or anything related to the nRF Sniffer. I did reboot Windows as well to make sure that all settings had taken effect:
Why doesn't the Interface Toolbars menu option appear?
I copied the Profile_nRF_Sniffer_v2_001 to the profiles folder with my Personal Configuration folder:
I can see this in the WireShark > Edit > Configuration Profiles:
However, when I select Profile_nRF_Sniffer_v2_001, it does not show up on the main WireShark page:
Consequently, I don't capture any packets using the nRF52-DK. Can anyone see what I might be doing wrong? Is there a problem with the .bat file? And why doesn't the nRF Sniffer show up under View/Interface Toolbars?
Also, are there any plans to port the nRF Sniffer to the nRF52840-Dongle? I have one of those as well, and it would be preferable to use that than to tie up two nRF52-DK's.
I'm happy to provide other information. Thanks very much for your time and help.
Scott
