ut_generic_dtt_client fails with Mesh SDK 3.1.0
When running the unit tests for Mesh SDK 3.1.0 I get the following failures.
83/92 Test #83: generic_dtt_client ...............***Failed 0.00 sec
From the log I can see the following.
mesh/test/src/ut_generic_dtt_client.c:321:test_generic_dtt_client_set:FAIL: Expected 17 Was 7
This is because the parameter to the function is not initialized properly. The following patch solves the problem.
diff --git a/mesh/test/src/ut_generic_dtt_client.c b/mesh/test/src/ut_generic_dtt_client.c
index 696ea04..4cdf081 100644
--- a/mesh/test/src/ut_generic_dtt_client.c
+++ b/mesh/test/src/ut_generic_dtt_client.c
@@ -304,7 +304,7 @@ void test_generic_dtt_client_init(void)
 void test_generic_dtt_client_set(void)
-    generic_dtt_set_params_t set_params;
+    generic_dtt_set_params_t set_params = {0};
     generic_dtt_set_msg_pkt_t pkt;
     uint16_t opcode;
     uint16_t len;
I'm using GCC 8.2.1.
Thanks.
