in the code below. implemented on a mesh form multiple Clients (Publication addresses) to the server (subscriped) to all the clients.
The code reads beacon data, removes the Minor ID, combine it with the Client UUID . This needs to be sent to the server.
I would like to know
1. how to use the function : access_model_reliable_publish(); to transmit the array Result[24] from the code below
2. Max clients that can send data to 1 server on a mesh.
/* Models */
#include "generic_onoff_client.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
#include "nrf_delay.h"
#include "string.h"
#define APP_STATE_OFF (0)
#define APP_STATE_ON (1)
#define APP_UNACK_MSG_REPEAT_COUNT (2)
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
static bool m_device_provisioned;
char scanner_UUID[17]; // scanner 2 bytes + 1
//for below also investigate ? nrf_mesh_rx_cb_t This callback can be used to receive raw advertisement packets
static void rx_cb(const nrf_mesh_adv_packet_rx_data_t * p_rx_data) // used for listening for incoming packets with function nrf_mesh_rx_cb_set(rx_cb);
LEDS_OFF(BSP_LED_0_MASK); /* @c LED_RGB_RED_MASK on pca10031 */
char msg[64];
char beacon_Minor_ID[5]; // the length of the eMbeacon unique ID
char Result[24]; // 5+16+1 for nul term
char beacon_uuid[37]; // the length of EM microelectronics packet**** check this it may be shorter
// copy the UUID of the beacon
memcpy(beacon_uuid,p_rx_data->p_payload, p_rx_data->length); // copy the UUID of the beacon
// check if it is a EMbeacon Beacon make in bit 2:9
if ((beacon_uuid[2]==0x45)|(beacon_uuid[3]==0x4D)|(beacon_uuid[4]==0x42)|(beacon_uuid[5]==0x65)
|(beacon_uuid[6]==0x61)|(beacon_uuid[7]==0x63)|(beacon_uuid[8]==0x6f)|(beacon_uuid[9]==0x6e)) // EMBeacon name check
// if it is a beacon send PCA10059 (scanner) UUID and Beacon UUID to the client on the mesh
memcpy (beacon_Minor_ID,beacon_uuid + 10,5); // move the 5 unique beacon ID bytes for use in mesh to identify the beacon
memcpy(Result, (void*) &scanner_UUID[0], 16); // combine Beacon Minor UUID and Scanner complete UUID
memcpy(&Result[16], (void*) &beacon_Minor_ID[0], 8); // Advertisement address
// Transmit Result on the mesh to the gateway server.
Thanks in advance
