Read data inconsistency in external flash memory(QSPI exam)
Hello, everybody.
I'm working on combining the nRF52840 and the GPS module and are currently developing a program that stores real-time GPS data in an external flash memory(MX25R6435F).
So, I'm testing on Nordic DK board (PCA10056) that embedded MX25R6435F.
I tested it in your QSPI example and it worked very well. But I think this example is a bit of a problem. (Honestly, I don't know who the problem is: program or memory).
The problem is that QSPI_TEST_DATA_SIZE only works well above 80.   (Since GPS data that I use is 74 Bytes, it's problem)
[TX Buffer]
[RX Buffer]
[Code] : I have changed QSPI_TEST_DATA_SIZE. line 69.
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup qspi_example_main main.c
 * @ingroup qspi_example
 * @brief QSPI Example Application main file.
 * This file contains the source code for a sample application using QSPI.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "nrf_drv_qspi.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "sdk_config.h"
#define QSPI_STD_CMD_WRSR   0x01
#define QSPI_STD_CMD_RSTEN  0x66
#define QSPI_STD_CMD_RST    0x99
//#define QSPI_TEST_DATA_SIZE 256    /*< Nordic Original Code */
#define QSPI_TEST_DATA_SIZE 74    /*< Test Code */
#define WAIT_FOR_PERIPH() do { \
        while (!m_finished) {} \
        m_finished = false;    \
    } while (0)
static volatile bool m_finished = false;
static uint8_t m_buffer_tx[QSPI_TEST_DATA_SIZE];
static uint8_t m_buffer_rx[QSPI_TEST_DATA_SIZE];
static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context)
    UNUSED_PARAMETER(event);
    UNUSED_PARAMETER(p_context);
    m_finished = true;
static void configure_memory()
    uint8_t temporary = 0x40;
    uint32_t err_code;
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
        .opcode    = QSPI_STD_CMD_RSTEN,
        .length    = NRF_QSPI_CINSTR_LEN_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    // Send reset enable
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    // Send reset command
    cinstr_cfg.opcode = QSPI_STD_CMD_RST;
    // Switch to qspi mode
    cinstr_cfg.opcode = QSPI_STD_CMD_WRSR;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_2B;
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &temporary, NULL);
    uint32_t i;
    uint32_t err_code;
    err_code = NRF_LOG_INIT(NULL);
    NRF_LOG_INFO(""
                 "QSPI write and read example using 24bit addressing mode");
    srand(0);
    for (i = 0; i < QSPI_TEST_DATA_SIZE; ++i)
        m_buffer_tx[i] = (uint8_t)rand();
    nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG;
    err_code = nrf_drv_qspi_init(&config, qspi_handler, NULL);
    NRF_LOG_INFO("QSPI example started.");
    configure_memory();
    m_finished = false;
    err_code = nrf_drv_qspi_erase(NRF_QSPI_ERASE_LEN_64KB, 0);
    WAIT_FOR_PERIPH();
    NRF_LOG_INFO("Process of erasing first block start");
    err_code = nrf_drv_qspi_write(m_buffer_tx, QSPI_TEST_DATA_SIZE, 0);
    WAIT_FOR_PERIPH();
    NRF_LOG_INFO("Process of writing data start");
    err_code = nrf_drv_qspi_read(m_buffer_rx, QSPI_TEST_DATA_SIZE, 0);
    WAIT_FOR_PERIPH();
    NRF_LOG_INFO("Data read");
    NRF_LOG_INFO("Compare...");
    if (memcmp(m_buffer_tx, m_buffer_rx, QSPI_TEST_DATA_SIZE) == 0)
        NRF_LOG_INFO("Data consistent");
        NRF_LOG_INFO("Data inconsistent");
    nrf_drv_qspi_uninit();
    for (;;)
What causes the issues found above and how should they be addressed?
I current use:
  • SDK 15
  • Segger Embedded Studio 3.34
  • Windows 10
  • PCA10056
  • embedded flash memory (MX25R6435F)
I look forward to your reply, Thank you Slight smile
