PPK (nRF6707) error "Failed to read PPK metadata" on measuring external device with external supply
Getting "Failed to read PPK metadata" issue on measuring current of external device with external supply. I use nRF6707 PPK booth with PCA10028 or PCA10040 (doesn't work in booth cases), this tutorial. In case of onboard regulator supply it works in 10% cases (after reconnenction try) - otherwise "Failed to read PPK metadata", in case of external device supply it always return  "Failed to read PPK metadata". I have seen the same problems in forum, but no one answer for solving that issue. OS Linux
I successfully used measuring before on the Windows 7, but now in the Linux and in the Windows 10 i have that issue, i suppose it was happened after nrf Connect for desktop update.
Can anyone explain the reasons of appearing this error or how to resolve it?
Thanks.
16:59:48.442 Application data folder: /home/anton/.config/nrfconnect/pc-nrfconnect-ppk
16:59:48.520 App initialized
16:59:57.534 PPK opened
16:59:57.535 Initializing the PPK
16:59:58.837 Segger serial: 681744710
16:59:58.838 Segger speed: 2000 kHz
16:59:58.838 Segger version: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 12 2018 11:44:41
17:00:01.339 Failed to read PPK metadata
17:00:01.340 Failed to start the PPK.
