Increase max packets
I'm using BLE on nrf52832 and softdevice s132. It seems that when I send too many packets (around 45), the ble crashes. Is there a way to increase that number or at least make it not crash?
Thanks
  • What BLE profile are you using - eg, NUS?
    You should get an error status telling you when the SD can't accept more packets - are you paying attention to that?
  • NUS profile (uart).
    To clarify, the crash happens when I send data from microcontroller STM32 to the nordic nrf52 that's connected to it via uart, and then send the data to a smartphone by BLE.
    What error should I get? I looked through the error codes (0 to 19) and I can't find anything related to accepting packets.
    Also, if I get this error, what can I do?
    Here's some of the code inside uart_event_handle() under the case APP_UART_DATA_READY:
    do
        err_code = ble_nus_string_send(&m_nus, data_array, &length);
        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) )
    } while (err_code == NRF_ERROR_RESOURCES);
    Or should I be looking somewhere else?
    Thanks
  • You need to investigate to see what happens immediately before the crash.
    Maybe you're getting NRF_ERROR_RESOURCES - that sounds a likely candidate, doesn't it?
    Instrument your code to see what's happening.
    The link has a finite capacity - you can't just keep chucking data at it over that capacity.
    Only you can decide what's appropriate for your application in this situation
    • just discard excess data?
    • if the data is "bursty", buffer it somewhere?
    • tell the STM32 to stop sending data?
    • compress the data?
    • decimate the data?
    • adjust the link parameters to increase throughput?
    • etc, etc, ...
  • Thanks for the response,
    I verified that the error that I'm getting is NRF_ERROR_RESOURCES.
    Regarding the capacity, let's say maximum packets is 40 of size 20. Does that mean that if I send, say 40 packets of size 20, then wait some time, and then continue sending, it will work successfully? How much should the waiting time be?
    Thank you
  • Arbitrary delays are never a good idea.
    Better to look for a specific indication that the link again has capacity.
    If you are constantly hitting this, it indicates that you need to re-evaluate something - either send less data, or adjust the link parameters to increase throughput
