I have Nordic NRF 52840 DK development board, using Ubuntu 18.04, I loaded "ble_connectivity_s140_usb_hci_pca10056" to the board successfully. Then I powered cycle and cannot get it to connect to Bluetooth Low engergy app whatsoever:
2:54:36.765
Validating connectivity firmware for device with serial number DAE038DE778D...
12:54:36.778
Connectivity firmware is valid.
12:54:36.779
Connectivity firmware version: ble-connectivity 0.1.0+Aug-14-2018-15-12-51. SoftDevice API version: 3. Baud rate: 1000000.
12:54:36.779
Opening adapter connected to /dev/ttyACM0
12:54:37.292
Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
12:54:37.294
Reset performed on adapter /dev/ttyACM0
12:54:37.294
Received status with code 5 IO_RESOURCES_UNAVAILABLE, message: 'UART implementation failed while reading bytes from UART port /dev/ttyACM0.'
12:54:37.468
Device closed.
The issue is every time the software initializes the connection a reset is performed, this changes the UART port back and forth from ttyACM0 to ttyACM1 so the next step it tried to read will fail. This issue also exists with the nrf52840 Dongle but for the dongle I just unplug it every time and it seemed fine. But I cannot do that trick with the DK kit.
