We are using SDK 15.0 and Softdevice 6.0, nRF52832
The question is :(1) We migrated the example "ble_app_hrs_freertos" to "ble_app_uart_c",luckily it works ;(2) But when we add a new task "task2" (just NRF_LOG_INFO("It's OK!")) for loop every 1 senconds . Then the question is : The task2 just work three times and not work again; or the BLE task and task2 both not work!
We can't find the reason! Please help us! Thanks very much!
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "app_timer.h"
#include "app_util.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_db_discovery.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//---------------------------------BLE Uart-------------------------------------
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
(uint16_t)SLAVE_LATENCY, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.active = 1,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void * p_context)
ret_code_t ret;
ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
APP_ERROR_CHECK(ret);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
static uint16_t t_num = 0;
/**@brief Function for handling characters received by the Nordic UART Service.
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
t_num++;
if(t_num == 20)
t_num = 0;
NRF_LOG_HEXDUMP_INFO(p_data,data_len);
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
ret_code_t err_code;
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
/* 连接以后,给对方发送 “传输数据的指令” */
char begin = 69;
ble_nus_c_string_send(p_ble_nus_c, &begin, 1);
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start(NULL);
/**@brief Function for handling the advertising report BLE event.
* @param[in] p_adv_report Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
char Name[] = "podoon";
// if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
if(ble_advdata_name_find(p_adv_report->data.p_data, p_adv_report->data.len, Name))
NRF_LOG_INFO("Podoon has beening finden!");
err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
&m_scan_params,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
if (err_code == NRF_SUCCESS)
NRF_LOG_INFO("Podoon has beening Connected!");
err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&p_gap_evt->params.adv_report);
break; // BLE_GAP_EVT_ADV_REPORT
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected to target");
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_INFO("Scan timed out.");
scan_start(NULL);
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
//---------------------------------FreeRTOS-------------------------------------
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread; /**< Definition of Logger thread. */
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
* @details This thread is responsible for processing log entries if logs are deferred.
* Thread flushes all log entries and suspends. It is resumed by idle task hook.
* @param[in] arg Pointer used for passing some arbitrary information (context) from the
* osThreadCreate() call to the thread.
static void logger_thread(void * arg)
UNUSED_PARAMETER(arg);
while (1)
NRF_LOG_FLUSH();
vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
* @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
vTaskResume(m_logger_thread);
TaskHandle_t xTaskHandle_Test;
void vTaskFunction_TaskTest(void * pvParameter)
UNUSED_PARAMETER(pvParameter);
while (true)
NRF_LOG_INFO("=================================================");
NRF_LOG_FLUSH();
/* Delay a task for a given number of ticks */
vTaskDelay(1000);
/* Tasks must be implemented to never return... */
// Initialize.
bool erase_bonds;
1. */
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("||Initialize||---->>LOG---->>completed!");
2.
@brief Function for initializing the nrf_drv_clock module.
After initialization, the module is in power off state (clocks are not requested). */
err_code = nrf_drv_clock_init();
NRF_LOG_INFO("||Initialize||---->>nrf_drv_clock---->>completed!");
3. _FreeRTOS xTask
Do not start any interrupt that uses system functions before system initialisation.
The best solution is to start the OS before any other initalisation. */
#if NRF_LOG_ENABLED
// Start execution.
if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
/*(1) */
// if (pdPASS != xTaskCreate(vTaskFunction_TaskTest, "TTest", 256, NULL, 2, &xTaskHandle_Test))
// APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
NRF_LOG_INFO("||Initialize||---->>xTaskCreate---->>completed!");
db_discovery_init();
ble_stack_init();
gatt_init();
nus_c_init();
Create a FreeRTOS task for the BLE stack.
The task will run advertising_start() before entering its loop.*/
nrf_sdh_freertos_init(scan_start, &erase_bonds);
Start FreeRTOS scheduler.*/
vTaskStartScheduler();
// Enter main loop.*/
NRF_LOG_INFO("||Wrong ||---->>FreeRTOS---->>Quite !!");
for (;;)
APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
