NFC - communicaiton problem
Dear Nordic,
  • I am using nrf52DK
  • I modified "examples\nfc\writable_ndef_msg"
  • I am using an ingenico POS payment terminal
The working flow is ;
  • pos sends apdu-1,  nrf52dk  receives and  responds
  • pos sends apdu-2,  nrf52dk receives and responds
  • pos sends apdu-3,  nrf52dk receives and responds
  • and transaction flow is finished.
below you can find we respond to pos terminal ;
case NFC_T4T_EVENT_DATA_TRANSMITTED:
NRF_LOG_DEBUG("Data Transmitted!");
bsp_board_led_on(BSP_BOARD_LED_1);
NRF_LOG_DEBUG("Default event!");
NRF_LOG_DEBUG("Data length: %u bytes.", dataLength);
NRF_LOG_HEXDUMP_DEBUG(data, dataLength);
if (memcmp(data, PPSE, 20) == 0) {
uint8_t tmpData[] = { 0x6F, 0x23, 0x84, 0x0E, 0x32, 0x50, 0x41, 0x59, 0x2E, 0x53,
0x59, 0x53, 0x2E, 0x44, 0x44, 0x46, 0x30, 0x31, 0xA5, 0x11,
0xBF, 0x0C, 0x0E, 0x61, 0x0C, 0x4F, 0x07, 0xa0, 0x00, 0x00,
0x06, 0x72, 0x30, 0x10, 0x87, 0x01, 0x01, 0x90, 0x00};
uint8_t tmpDataLen = 39;
nfc_t4t_response_pdu_send(tmpData,tmpDataLen);
} else if (memcmp(data, PPSE, 3) == 0) {
uint8_t tmpData1[] = { 0x6F, 0x4C, 0x84, 0x07, 0xA0, 0x00, 0x00, 0x06, 0x72, 0x30,
0x10, 0xA5, 0x41, 0x50, 0x10, 0x54, 0x52, 0x4F, 0x59, 0x20,
0x42, 0x41, 0x4E, 0x4B, 0x41, 0x20, 0x4B, 0x41, 0x52, 0x54,
0x49, 0x87, 0x01, 0x01, 0x9F, 0x38, 0x16, 0x9F, 0x66, 0x04,
0x9F, 0x02, 0x06, 0x9F, 0x03, 0x06, 0x9F, 0x1A, 0x02, 0x5F,
0x2A, 0x02, 0x9A, 0x03, 0x9C, 0x01, 0x9F, 0x37, 0x04, 0x5F,
0x2D, 0x08, 0x74, 0x72, 0x65, 0x6E, 0x64, 0x65, 0x66, 0x72,
0xBF, 0x0C, 0x05, 0x9F, 0x4D, 0x02, 0x0B, 0x04, 0x90, 0x00};
uint8_t tmpDataLen1 = 80;
nfc_t4t_response_pdu_send(tmpData1,tmpDataLen1);
} else if (memcmp(data, GPO, 3) == 0) {
uint8_t tmpData2[] = { 0x77, 0x5F, 0x82, 0x02, 0x18, 0x00, 0x9F, 0x26, 0x08, 0x0F,
0xED, 0x72, 0xAA, 0x6C, 0xA9, 0x37, 0xA0, 0x9F, 0x36, 0x02,
0x00, 0x01, 0x9F, 0x10, 0x11, 0x01, 0x15, 0x20, 0x10, 0x00,
0x00, 0x00, 0x00, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x9F, 0x27, 0x01, 0x80, 0x9F, 0x71, 0x02, 0x00,
0x08, 0x57, 0x13, 0x97, 0x92, 0x48, 0x84, 0x34, 0x05, 0x39,
0x22, 0xD2, 0x70, 0x56, 0x26, 0x00, 0x00, 0x07, 0x07, 0x00,
0x00, 0x0F, 0x5F, 0x34, 0x01, 0x01, 0x5F, 0x25, 0x03, 0x18,
0x11, 0x01, 0x9F, 0x07, 0x02, 0xAB, 0x00, 0x5F, 0x28, 0x02,
0x07, 0x92, 0x9F, 0x08, 0x02, 0x00, 0x01, 0x90, 0x00};
uint8_t tmpDataLen2 = 99;
nfc_t4t_response_pdu_send(tmpData2,tmpDataLen2);
The non-working flow is (with delays);
  • pos sends apdu-1,   nrf52dk receives apdu-1, 100 ms delay and then responds
in this case pos does not receive the response and sends first apdu-1again and again...
I attached the followings ;
  • working log
  • <debug> app: Field On!
    <debug> app: Default event!
    <debug> app: Data length: 20 bytes.
    <debug> app:  00 A4 04 00 0E 32 50 41|.....2PA
    <debug> app:  59 2E 53 59 53 2E 44 44|Y.SYS.DD
    <debug> app:  46 30 31 00            |F01.
    <debug> app: Data Transmitted!
    <debug> app: Data length: 13 bytes.
    <debug> app:  00 A4 04 00 07 A0 00 00|........
    <debug> app:  06 72 30 10 00         |.r0..
    <debug> app: Data length: 36 bytes.
    <debug> app:  80 A8 00 00 1E 83 1C 36|.......6
    <debug> app:  00 40 00 00 00 00 00 00|.@......
    <debug> app:  01 00 00 00 00 00 00 07|........
    <debug> app:  92 09 49 19 01 17 00 54|. I....T
    <debug> app:  E6 31 9E 00            |.1..
    <debug> app: Field Off!
  • non-working log
  • <debug> app: Default event!
  • main.c
     * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nfc_writable_ndef_msg_example_main main.c
     * @ingroup nfc_writable_ndef_msg_example
     * @brief The application main file of NFC writable NDEF message example.
    #include <stdint.h>
    #include <stdbool.h>
    #include "app_error.h"
    #include "app_scheduler.h"
    #include "boards.h"
    #include "nfc_t4t_lib.h"
    #include "nrf_log_ctrl.h"
    #include "ndef_file_m.h"
    #include "nfc_ndef_msg.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #define APP_SCHED_MAX_EVENT_SIZE 0                  /**< Maximum size of scheduler events. */
    #define APP_SCHED_QUEUE_SIZE     4                  /**< Maximum number of events in the scheduler queue. */
    #define APP_DEFAULT_BTN          BSP_BOARD_BUTTON_0 /**< Button used to set default NDEF message. */
    static uint8_t m_ndef_msg_buf[NDEF_FILE_SIZE];      /**< Buffer for NDEF file. */
    static uint8_t m_ndef_msg_len;                      /**< Length of the NDEF message. */
     * @brief Function for updating NDEF message in the flash file.
    static void scheduler_ndef_file_update(void * p_event_data, uint16_t event_size)
        ret_code_t err_code;
        UNUSED_PARAMETER(p_event_data);
        UNUSED_PARAMETER(event_size);
        // Update flash file with new NDEF message.
        err_code = ndef_file_update(m_ndef_msg_buf, m_ndef_msg_len + NLEN_FIELD_SIZE);
        NRF_LOG_INFO("NDEF message updated!");
     * @brief Callback function for handling NFC events.
    static void nfc_callback(void          * context,
                             nfc_t4t_event_t event,
                             const uint8_t * data,
                             size_t          dataLength,
                             uint32_t        flags)
        uint8_t PPSE[] = {0x00, 0xA4, 0x04, 0x00, 0x0E, 0x32, 0x50, 0x41, 0x59, 0x2E,
                          0x53, 0x59, 0x53, 0x2E, 0x44, 0x44, 0x46, 0x30, 0x31, 0x00};
        uint8_t GPO[] = {0x80, 0xA8, 0x00};
        (void)context;
        switch (event)
            case NFC_T4T_EVENT_FIELD_ON:
                NRF_LOG_DEBUG("Field On!");
                bsp_board_led_on(BSP_BOARD_LED_0);
            case NFC_T4T_EVENT_FIELD_OFF:
                NRF_LOG_DEBUG("Field Off!");
                bsp_board_leds_off();
            case NFC_T4T_EVENT_NDEF_READ:
                NRF_LOG_DEBUG("NDEF Read!");
                bsp_board_led_on(BSP_BOARD_LED_3);
            case NFC_T4T_EVENT_NDEF_UPDATED:
                NRF_LOG_DEBUG("NDef Updated!");
                if (dataLength > 0)
                    // Schedule update of NDEF message in the flash file.
                    m_ndef_msg_len = dataLength;
                    err_code       = app_sched_event_put(NULL, 0, scheduler_ndef_file_update);
                   nrf_delay_ms(100);
                   nrf_delay_ms(100);
                   nrf_delay_ms(100);
     *@brief Function for initializing logging.
    static void log_init(void)
     * @brief   Function for application main entry.
        log_init();
        /* Configure LED-pins as outputs */
        bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
        /* Initialize App Scheduler. */
        APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
        /* Set up NFC */
        /* Initialize FDS. */
        //err_code = ndef_file_setup();
        //APP_ERROR_CHECK(err_code);
        err_code = nfc_t4t_setup(nfc_callback, NULL);
        /* Start sensing NFC field */
        err_code = nfc_t4t_emulation_start();
        while (1)
            NRF_LOG_FLUSH();
            __WFE();
Can you help with this issue please ?
Kind Regards
Sami
