The table under 5.4.4.3 in the datasheet for the nRF52840 lists the shunt capacitance for the LFXO as 2pF max
C0_LFXO (Shunt capacitance) 2pF max
What is the risk if the shunt capacitance of the crystal I'm using is larger than 2pF?
Is there a risk that the crystal won't start up at all?
That it will take longer to start up?
That it won't be as consistent or accurate?
The crystal I'm using has a shunt capacitance of 1.2pF typical but 5pF max.
I hadn't noticed before because this spec is not in the datasheet for the crystal.
I only found out when I asked specifically for it.
