Starting with nRF52832
Hi, I'm just a beginner with Bluetooth. I want to make a simple bluetooth module, so I just bought nRF52832 and other devices like capacitors, inductors, crystal oscillator and antenna.
The thing is, I have no idea how to start with these chips. I was planning to make pcb with these, but wander is there any process I should do with nRF52832, like start setup.
I'm gonna make pcb with the reference layouts and have all components plus chip antenna.
In sum, I want to know overall procedure to make a new bluetooth module with nRF52832 and other components in the reference layouts. Please give me a big help. thank you.
  • Hi
    All you need in addition to what the reference design provides, is a way to power, and to program the nRF52832. I suggest you mount the following GPIO pins:
    • One pin connected to VDD, for voltage input
    • One pin connected to ground on the board.
    • One pin connected to SWDIO and one to SWDCLK. (Necessary to program the nRF52)
    • Optional: One pin connected to an analog input (AIN) for testing purposes.
    Keep in mind that this is the most basic way to make a bluetooth module, and you may want to add more input possibilities for additional features.
    Best of luck,
    Simon
  • Thank you for your kind reply Simon.
    I understand the needs for the pins, connected to VDD and ground, but still not sure about SWDIO and SWDCLK pins. I thought basic program is set in the nRF52832. So, if I connect the pins for VDD, ground, and AIN, is it possible to get simple signal through bluetooth?
    For example, assume I made a module( just by mounting the nRF52832 and other components) with reference layouts, plus antenna. Also I connect 3 GPIO pins for VDD, ground and AIN. In this stage, if I set analog input as 2 DC voltage, is it gonna send any signal through bluetooth? Just simple signal. I don't need any complicate control since I am starting as a beginner. I just want to check out any bluetooth signal.
    Thank you,
    Kyubeen
  • Hi
    Our chips do not come with any basic program unless you have ordered preprogrammed chips. So you will need to make room for pins to SWDIO and SWDCLK. I forgot to attach this link in my last reply which has a lot of useful tips when it comes to nRF52 design.
    Good luck and kind regards,
    Simon
