How to configure a passkey for central and for peripheral.
Hi there,
I cannot find a good example of one central and one peripheral, where they use a passkey between them, with one of them, the peripheral, is where the user type the pass key, and the central is the one that displays the passkey to be typed.
The documentation seems to be a bit hidden too, if I would try to write it from scratch.
I am using nRF52832, s132.
Regards
  • Hi.
    For the peripheral side, you can look at the Glucose Application example (examples\ble_peripheral\ble_app_gls).
    For the central side, you have to do some modifications for a central example, for example the  GATT Service Server Example Application (examples\ble_central\ble_app_gatts)
    Here is a diff file with the changes you have to make to that example:
    diff --git a/examples/ble_central/ble_app_gatts/main.c b/examples/ble_central/ble_app_gatts/main.c
    index 7d5022d..34e769c 100644
    --- a/examples/ble_central/ble_app_gatts/main.c
    +++ b/examples/ble_central/ble_app_gatts/main.c
    @@ -85,10 +85,10 @@
     #define APP_SOC_OBSERVER_PRIO     1                                /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
     #define SEC_PARAM_BOND            1                                /**< Perform bonding. */
    -#define SEC_PARAM_MITM            0                                /**< Man In The Middle protection not required. */
    +#define SEC_PARAM_MITM            1                                /**< Man In The Middle protection not required. */
     #define SEC_PARAM_LESC            0                                /**< LE Secure Connections not enabled. */
     #define SEC_PARAM_KEYPRESS        0                                /**< Keypress notifications not enabled. */
    -#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE             /**< No I/O capabilities. */
    +#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_KEYBOARD_ONLY    /**< No I/O capabilities. */
     #define SEC_PARAM_OOB             0                                /**< Out Of Band data not available. */
     #define SEC_PARAM_MIN_KEY_SIZE    7                                /**< Minimum encryption key size. */
     #define SEC_PARAM_MAX_KEY_SIZE    16                               /**< Maximum encryption key size. */
    @@ -293,6 +293,19 @@ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
             } break;
    +        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
    +          NRF_LOG_DEBUG("GAP Passkey request.");
    +          uint8_t passkey[] = "000000";
    +          if (p_gap_evt->params.auth_key_request.key_type == BLE_GAP_AUTH_KEY_TYPE_PASSKEY)
    +              err_code = sd_ble_gap_auth_key_reply(p_gap_evt->conn_handle, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, passkey);
    +              APP_ERROR_CHECK(err_code);
    +        } break;
    diff --git a/examples/ble_central/ble_app_gatts/pca10040/s132/config/sdk_config.h b/examples/ble_central/ble_app_gatts/pca10040/s132/config/sdk_config.h
    index c48d10b..96949d4 100644
    --- a/examples/ble_central/ble_app_gatts/pca10040/s132/config/sdk_config.h
    +++ b/examples/ble_central/ble_app_gatts/pca10040/s132/config/sdk_config.h
    @@ -7434,7 +7434,7 @@
     // <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
     #ifndef NRF_LOG_BACKEND_RTT_ENABLED
    -#define NRF_LOG_BACKEND_RTT_ENABLED 0
    +#define NRF_LOG_BACKEND_RTT_ENABLED 1
     // <o> NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
     // <i> Size of the buffer is a trade-off between RAM usage and processing.
    @@ -7467,7 +7467,7 @@
     // <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
     #ifndef NRF_LOG_BACKEND_UART_ENABLED
    -#define NRF_LOG_BACKEND_UART_ENABLED 1
    +#define NRF_LOG_BACKEND_UART_ENABLED 0
     // <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
     #ifndef NRF_LOG_BACKEND_UART_TX_PIN
    diff --git a/examples/ble_peripheral/ble_app_gatts_c/main.c b/examples/ble_peripheral/ble_app_gatts_c/main.c
    index ebd2823..74a8a9c 100644
    --- a/examples/ble_peripheral/ble_app_gatts_c/main.c
    +++ b/examples/ble_peripheral/ble_app_gatts_c/main.c
    @@ -147,6 +147,7 @@ static void gap_params_init(void)
         ret_code_t              err_code;
    +    ble_opt_t               ble_opt;
    @@ -164,6 +165,11 @@ static void gap_params_init(void)
    +    ble_opt.gap_opt.passkey.p_passkey = "000000";
    +    err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &ble_opt);
    diff --git a/examples/ble_peripheral/ble_app_gatts_c/pca10040/s132/config/sdk_config.h b/examples/ble_peripheral/ble_app_gatts_c/pca10040/s132/config/sdk_config.h
    index 93b1b15..efe405d 100644
    --- a/examples/ble_peripheral/ble_app_gatts_c/pca10040/s132/config/sdk_config.h
    +++ b/examples/ble_peripheral/ble_app_gatts_c/pca10040/s132/config/sdk_config.h
    @@ -90,7 +90,7 @@
     // <4=> BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY
     #ifndef SEC_PARAM_IO_CAPABILITIES
    -#define SEC_PARAM_IO_CAPABILITIES 3
    +#define SEC_PARAM_IO_CAPABILITIES 0
     // <o> SEC_PARAM_MAX_KEY_SIZE - Maximum encryption key size in octets between SEC_PARAM_MIN_KEY_SIZE and 16.  <0-16>
    @@ -111,7 +111,7 @@
     #ifndef SEC_PARAM_MITM
     // <q> SEC_PARAM_OOB  - Out Of Band data not available or not
    @@ -7419,7 +7419,7 @@
    @@ -7452,7 +7452,7 @@
    Andreas
  • Hi Andreas,
    Thanks for the information.
    I have yet a few questions...
    Right, so if I understand your diff right, the peripheral is the one that has a preconfigured passkey, and the central is the one that is asked about it.
    Can it be the other way around at all, or does it always work like that?
    Looking at the only example that seems to use XXX_WITH_MITM is the multirole in central and peripheral. The interactive does it too, but for an autonomous example, the multirole seems the only one.
    Isn't the MITM needed for a passkey, or the passkey can be used without it but then it is just a way to ensure you pair to the right device, but no MITM protection?
    I believe I have seen some examples in the forum of explicit checks for the mitm config in the peer manager SEC_SUCCEEDED event, disconnecting if it is not set.
    Is that the right way to enforce the MITM usage, or does the PM ensure that some other way?
    If I have a peripheral that supports MITM and one that does not, can they both be paired to a central?
    I see that the multirole seems to run ble_lesc_init, which seesm to be required for MITM.... should that be run in both central and peripheral?
    Regards
  • Hi.
     Sorry about this, I see that the diff file now might be a bit confusing
    The central has a "preconfigured passkey", on line 27:
    "+          uint8_t passkey[] = "000000"; "
    From line 60:
    "diff --git a/examples/ble_peripheral/ble_app_gatts_c/main.c b/examples/ble_peripheral/ble_app_gatts_c/main.c"
    The peripheral side and a hardcoded passkey is set up, note that this is another project (ble_app_gls lets you write the passkey as an input on the peripheral side).
     Passkey is a form of MITM protection. But only using passkey is not safe, as the passkey has no encryption when it is transmitted over the air, and for that you need LESC.
    The Peer manager is created and used for handling pairing and bonding, so you can use it if you like. They should do the same job, but it might be less work for you using the Peer manager.
     Yes, they can. You can have support for MITM and not demand that each device that connects should use MITM.
    Yes. in the multirole example this is done through pm_init() -> sm_init() --> nrf_ble_lesc_init()
    Andreas
  • Hi andreas,
    Thanks again for clarifying.
    On this though:
    From line 60:
    What I mean is that the central seems to be the one that sends the passkey (lines 30-31), while the gls peripheral seems to just display the received passkey. So it suggests to me that you type it in the central, and then it is sent to the peripheral.
    I was wondering if it is possible for the peripheral to be used to key in the passkey and then send it to the central instead.
    Regards
  • Hi.
     Yes, this should be possible. You should only have to do it the opposite way around than the diff file.
    Andreas
  • Do I actually get the BLE_GAP_EVT_AUTH_KEY_REQUEST event on both devices?
  • Hi.
    Yes, according to these Message Sequence Charts, you can get this event on both sides.
    Central Legacy Pairing.
    Peripheral Legacy Pairing.
    Andreas
