problems with differential SAADC reading of floating voltage, nRF52840
I'm trying to read a voltage from my power supply using the differential SAADC on my board to simulate the readings from a thermopile that I ordered so I can start calibrating/characterizing the ADC. The voltage output from the supply across V+ and V- is 0.060V. However the readings I'm getting from the SAADC read call is -8191 counts every time (-0.150V) which is the max input voltage. I find this very strange. I've verified that the supply is truly outputting 0.060V with my bench-top DMM.
I've tried connecting V- to GND on the board and the negative probe on the ADC but this does not improve the results.
I've also tried connecting the supply GND to the board GND and that didn't yield good results either.
I also have tried connecting V+ to pin_p and V- to pin_n.
Another thing I've tried is enabling the pull-up and pull-down resistors on the pin_p and pin_n pins on the SAADC.
I'm certain that my driver usage is not incorrect as I have been able to make good measurements on single-ended readings and differential readings of other known sources. I'm a mechanical engineer so I feel there may be some gaps in my knowledge of reading floating voltages. Do you know what is happening here or how I might be able to get good measurements? What changes do I need to make to the circuit?
Info:
SDK version: 15.0.0
Dev board: PCA10056
Differential reading method: SAADC driver (nrfx_saadc.h)
Powering board from usb to computer.
SAADC configs:
.resolution = NRF_SAADC_RESOLUTION_14BIT,
.oversample = NRF_SAADC_OVERSAMPLE_128X,
.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY,
.low_power_mode = true
Channel configs:
.resistor_p = NRF_SAADC_RESISTOR_DISABLED,
.resistor_n = NRF_SAADC_RESISTOR_DISABLED,
.gain = NRF_SAADC_GAIN4,
.reference = NRF_SAADC_REFERENCE_INTERNAL, // 0.6V
.acq_time = NRF_SAADC_ACQTIME_40US,
.mode = NRF_SAADC_MODE_DIFFERENTIAL,
.burst = NRF_SAADC_BURST_ENABLED,
.pin_p = NRF_SAADC_INPUT_AIN6, // P0.30
.pin_n = NRF_SAADC_INPUT_AIN1 // P0.03
Converting counts to voltage: (counts are uint16_t)
Input range = ±0.6 V / gain (4) = ±0.150V
V_read = counts * reference / gain * 2^-(resolution - 1) = counts * 18.31055 e-06
