nRF52832 ADC
I try to combine SPI master and ADC sample code, I add below code to my spi master example, the saadc_init() is called in the main function. However I found that the saadc_callback is not called after a while. Please comment!
I am using nRF5_15.2.0 SDK
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
  //      int i;
   //     NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    Where do you trigger your saadc samples from? Where is nrf_drv_saadc_sample() called? Can I see your entire main.c file?
    BR,
    Edvin
  • Dear Edvin,
    Below is my code. nrf_drv_saadc_buffer_convert() is called at saadc_init(). Therefore, I expect that  saadc_callback will be called after the conversion is completed. Right?
      //      int i;
    //   signed int temperature;
        saadc_init();
    //………  followed by the SPI code
    No. the buffer_convert will not trigger the sampling task for the saadc.
    If you look in the saadc example there are two functions, saadc_sampling_event_init() and saadc_sampling_event_enable(). It is not trivial, but what these functions do is to connect the sampling function to a timeout callback of a timer using the PPI (which is done in saadc_sampling_event_enable()) and then enable this link (which is done in saadc_sampling_event_enable()).
    You can either use this approach to trigger the samples. Each time a sample is trigged, one sample is taken (one sample per channel, if several saadc_channels are enabled, but it looks like you only have one). Note that you have to do n samples before the saadc callback is called, where n = SAMPLES_IN_BUFFER.
    To play around with the sampling event, I made a project that triggers one sample by a button press. The main.c and sdk_config.h file for this project is included here. It should work if you replace main.c and sdk_config.h from the saadc example from SDK15.2.0 with these. Note that it does not use saadc_sampling_event_enable() and saadc_sampling_event_enable(), but the button_handler to trigger the saadc_sampling.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nrf_adc_example main.c
     * @ingroup nrf_adc_example
     * @brief ADC Example Application main file.
     * This file contains the source code for a sample application using ADC.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_gpiote.h"
    #define SAMPLES_IN_BUFFER 8
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
            int i;
        // Init channel 0:
        // Init channel 1:
        channel_config.pin_p = NRF_SAADC_INPUT_AIN1;
        err_code = nrf_drv_saadc_channel_init(1, &channel_config);
    //    // Init channel 2:
    //    channel_config.pin_p = NRF_SAADC_INPUT_AIN2;
    //    err_code = nrf_drv_saadc_channel_init(2, &channel_config);
    //    APP_ERROR_CHECK(err_code);
    //    // Init channel 3:
    //    channel_config.pin_p = NRF_SAADC_INPUT_AIN3;
    //    err_code = nrf_drv_saadc_channel_init(3, &channel_config);
    void my_button_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        if (nrf_drv_gpiote_in_is_set(pin))
            NRF_LOG_INFO("button %d released", pin - BSP_BUTTON_0);
            NRF_LOG_INFO("button %d pressed", pin - BSP_BUTTON_0);
            nrf_drv_gpiote_out_toggle(BSP_LED_0);
            nrfx_saadc_sample();
    void gpiote_init(uint32_t button_pin_number)
        nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
        err_code = nrf_drv_gpiote_out_init(BSP_LED_0, &out_config);
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        in_config.pull = NRF_GPIO_PIN_PULLUP;
        err_code = nrf_drv_gpiote_in_init(button_pin_number, &in_config, my_button_handler);
        nrf_drv_gpiote_in_event_enable(button_pin_number, true);
        nrf_drv_gpiote_out_set(BSP_LED_0);  // Turn off LED.
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
        gpiote_init(BSP_BUTTON_0);
        saadc_init();
        //saadc_sampling_event_init();
        //saadc_sampling_event_enable();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    sdk_config.h
    Edvin
  • I have followed your instruction. However, the saadc_callback still cannot be triggered. attached please find my main.c and sdk_config.h file
    4405.sdk_config.h
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #define SAMPLES_IN_BUFFER 5
    #define USB_DETECT 24
    bool adc_complete = true;
    //static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    //static nrf_ppi_channel_t     m_ppi_channel;
    int16_t  ADC_data, ADC_data_bat_mon_enable,ADC_data_bat_mon_disable;
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "BLE temperature probe"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
            int i;
        // Init channel 0:
        // Init channel 1:
    /**@brief Function for application main entry.
    //    bool ble_advertise= false;
        uint32_t err_code;//usb_detect_status;
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        for (;;)
          if(adc_complete)
            adc_complete = false;
             err_code = nrfx_saadc_sample();
        //    err_code = nrf_drv_saadc_sample_task_get();
       //     idle_state_handle();
      //           nrf_pwr_mgmt_run();
       //     NRF_LOG_FLUSH();
     You need to do several samples to trigger the event. As of now, you start with adc_complete=true, and you trigger one sample, and then you wait for the event before setting adc_complete to true again. But this will not happen before you do 4 more samples, because your SAMPLES_IN_BUFFER = 5, and you need to fill this buffer with samples before you get the saadc callback event.
    Also, you don't process your logging, so even if you would get the ADC events, you wouldn't see it in your log, because NRF_LOG_FLUSH() is commented out.
    Have you tried the saadc example from SDK\examples\peripheral\saadc ?
    Try to copy all of the functions from this example. saadc_init(), saadc_sampling_event_init() and saadc_sampling_event_enable(), and for good measure, include NRF_LOG_FLUSH() and nrf_pwr_mgmt_run() as well.
  • I have tried the saadc example. It work. All my pcb boards are sent to customer, I have no boards to try now. I will try to set the SAMPLES_IN_BUFFER to 1 for next batch. The callback will be triggered every time I call nrfx_saadc_sample() if I set  SAMPLES_IN_BUFFER to 1. Right?
    SAMPLES
  • yes. But you should trigger this using a timer rather than in the callback event.
    With your implementation below you risk that nrfx_saadc_sample() does not return NRF_SUCCESS for some reason. In this case, adc_complete is false, and you have not triggered a new sample, and you will not get a new callback, and never trigger the new sample.
    Therefore you should at least not set adc_complete to false without checking that nrfx_saadc_sample() returned true.
