nRF52832 and SHT11 GPIO bit bang
I'm trying to use this code https://github.com/kimyd/SHT1X_on_nrf51822 to communicate with an SHT11 sensor via GPIO pins.  I have a Saleae hooked up an can see the pulses and everything looks okay until the command ACK stage.  The data pin is never pulled low indicating the sensor did not receive the command.  I know the sensor is good as it works find with a RPi using python.
Is there something I need to configure on the GPIO data pin to allow it to be both input and output (I'm just going with S0S1 for the drive).
Any tips/pointers would be greatly appreciated.
Thanks.
    The new plot was much better Slight smile Can you upload the code which calls your s_write_byte() as well? I am wondering because you wrote that  you write the code word for humidity (000 00101), but it looks to me like you write 000 00111 (Read Status Register). But that does not impact the main issue here, as in any case the SHT11 should have acknowledged by pulling down the data line (according to the datasheet).
    If the data and clock line matches what you get from the RPi, then there is something else preventing the SHT11 from receiving or acking. Is the signal voltage for data and clock at the SHT11 acceptable compared to VDD? Logic '1' should be at least 80% of VDD.
  • Hi Einar,
    Looks like you have identified the 'smoking gun'.  Both my data and clock line are nowhere near 80% of VDD but I have no idea why.  Here are my readings:
    VDD: 4.929V (5V pin on 52832)
    Data Output: 3.436V (you can see it is higher at the end of the trace/picture after I release the data pin)
    Data Input: 2.946V
    Clock Output: 2.767V
    My calculator tells me 80% of 4.929V should be around 3.94V (which is close to data input but not quite).
    Here is a picture:
    Any ideas on how I can raise the voltage levels on Data and Clock to hit 80% VDD (short of a transistor or some kind of relay)?  Given this works on a Pi I'm thinking I need to configure the GPIO pins in some manner.
    Apologies on the code/command mix up.  I've change the code around so many times I mixed up the command order.  The attached image is a: reset, transmission start, read temp command.
    Rob.
  • Hi Einar,
    I tried using S0H1 for the output settings but that had little to no effect on the voltage levels I'm seeing (both data and clock outputs are 2.89V.  Out of interest I pulled the SHT out and tried the code which resulted in the same readings both clock and data only reach 2.89V so it's nothing to do with the SHT.
    Doh - okay (I'm a dummy/bit slow), I use VDD instead of the +5V pin and everything looks to be working.  So I guess my questions now is how to re-adjust the GPIO output levels to use +5V?
    I am glad to hear you found the issue. It all made sense in the end Slight smile
    Regarding GPIO voltage, that is always the same as VDD on nRF5 devices, so it is not configurable. I do not see a need for changing it in this case, but if it is needed for some reason, then you have to use a level shifter.
  • Thanks again for the help - I'm not sure how to mark this closed/answered.
